HPX lines
Old Jul 19, 2006 | 07:25 PM
dvfd12's Avatar
dvfd12
HPX lines
Are most of you using this? Where did you get the rigid hpx lines? All I have found is the braided or rubber ones.
Old Jul 19, 2006 | 07:28 PM
clux's Avatar
clux
Here's where I got mine:
http://members.***.net/kcmdieselperf...0Crossover.htm
Old Jul 19, 2006 | 07:42 PM
dvfd12's Avatar
dvfd12
Thank you clux.
RAMPAGE_F350's Avatar
RAMPAGE_F350
This is where I got mine.
http://www.itpdiesel.com/store.php?crn=98
Old Jul 19, 2006 | 08:38 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
KCM diesel performance is where i got mine. i got it at the link where Clux posted, however KCM sells their part to ITP and other providers. you will be getting the same thing with either place you buy it.
Old Jul 19, 2006 | 08:42 PM
dvfd12's Avatar
dvfd12
Thanks guys. I bought the one from KCM.
Old Jul 19, 2006 | 09:00 PM
aklim's Avatar
aklim
Besides making the sound "nicer" what does it do in actuality?
Old Jul 19, 2006 | 09:23 PM
PowerstrokeJunkie
it balances the oil pressure in the two oil rails in the cylinder heads. since there is only one Injection Control Pressure sensor, that is in the left head, it only reads the pressure from the driver's side bank, and it then sends pressure readings that in turn regulate oil pressure to both heads. using this part connects the oil galleries together, so it reads an accurate pressure from both heads. oil doesnt flow through the tube, so much as it acts as a "shock absorber" (PSNut) for the cylinder heads.
Old Jul 24, 2006 | 04:14 PM
Chance_Thomas's Avatar
Chance_Thomas
Will this help with any performance gain?
Old Jul 24, 2006 | 04:19 PM
wilbur996's Avatar
wilbur996
I found that after the install it made the go pedal really sensitive. Like as soon as you touch it, it was ready to go. Before it seemed kinda dull.
Besides taking some of the roughness out of the idle.
Old Jul 24, 2006 | 04:27 PM
arninetyes's Avatar
arninetyes
I saw no performance improvement, and my logbook tells me there was no fuel mileage improvement.
But it sounds and feels so much smoother and better... It was worth the effort.
Old Aug 7, 2006 | 06:29 PM
Chance_Thomas
I just did the HPX noticed it idles more queitly that is about it.
http://www.itpdiesel.com/store.php?c...on=show_detail
