E4OD replacement
Old Jan 18, 2014 | 02:24 PM
tigerblood's Avatar
tigerblood
E4OD replacement
1991 F250 4x4:
About a week ago it was really cold in IA, about -25, and one of my cooler lines came loose and I lost all my fluid, and I believe the trans burned up because after refilling it with fluid it slips really bad now.
I think Im going to just replace it with another one and not rebuild the one I have, my question is will any 87-96 E4OD from a 4x4 work for my application?
Old Jan 18, 2014 | 02:29 PM
Chefsteele's Avatar
Chefsteele
Originally Posted by tigerblood
1991 F250 4x4:
After your test drive was the oil at the same level during Ideal?
Old Jan 18, 2014 | 02:31 PM
tigerblood's Avatar
tigerblood
yeah, Ive actually driven it a 3 times now, and each time I check the fluid level hot while in "P" as directed, so Im confident it has the correct amount of fluid in it.
Old Jan 18, 2014 | 02:43 PM
Chefsteele's Avatar
Chefsteele
If it where me I would pull the tyranny pan, to have a look see. when the clutches burn up you will see metallic particles. new clutch kit cost about $180.00 they are easy to rebuild. just got be carful pulling the tyranny manifold. the hardest part is the R&R.
their are a lot of other smart people here that probably help much better then I can.
Old Jan 18, 2014 | 04:22 PM
Lead Head's Avatar
Lead Head
E4ODs are not easy to rebuild, and require a few specialized tools to gear to the rear-most clutches. The valve-bodies are easy to mess up too.
mikeismadness
1978 - 1996 Big Bronco
Jun 1, 2011 06:57 PM
pikeslyr
Apr 7, 2011 11:01 AM
lonecountryboy
Jan 26, 2010 04:31 PM
Ten_Vojak
Nov 21, 2008 10:48 AM
00bucker
Feb 22, 2007 07:32 PM
