E4OD drained on the road
Old Nov 19, 2008 | 06:54 PM
Ten_Vojak's Avatar
Ten_Vojak
I have a 1990 Ford F-250 with a 7.3l diesel engine and E4OD transmission. The truck has about 208k on it and the transmission was rebuilt early 2007.
I was driving in the Texas Panhandle on Saturday morning. The temp outside was about 25 degrees. I had driven 90 miles at 55mph and everything was fine.
Since I was running late, I kicked the speed up to 60-65. I stopped in Lamesa - about 40 miles later to check the map and saw all of the transmission fluid draining out on the ground.
Could this have been because the transmission overheated or something else? I got an estimate for a partial rebuild of $800.
Any comments?
Thanks in advance
Old Nov 19, 2008 | 08:04 PM
jk080's Avatar
jk080
Transmission Rebuilder
It depends on where it is leaking from.
If it coming out the vent then the first thing that comes to mind would be that if it was just a little bit overfilled it could have just vented the excess fluid. E40Ds have alot of fluid, when fluid gets hot it expands, it can raise the level enough to leak from the vent.
Check the fluid level, if it is normal or full then it was probably overfilled.
If its low it might have a problem with the front seal area, it can leak out the front when hot if the pump bushing is worn.
Old Nov 20, 2008 | 01:08 AM
aurgathor's Avatar
aurgathor
Don't jump into a rebuild unless you know the tranny needs it. Let it cool down, check the level, and see if it still leaks.
Old Nov 21, 2008 | 10:48 AM
89ranger2.9's Avatar
89ranger2.9
I agree, shut it off, check the fluid and if it needs some fill it to the full line. If it was low while you were driving and it was still shifting with low fluid, could have burned some clutch packs and bands. You might just be fine if you caught it before it started slipping.
