Need some help.
Old Jan 18, 2014 | 10:00 AM
  #31
Fal-308-Win's Avatar
Fal-308-Win
Also read a thread on the first page " new gauge, new info. Some questions" rusty posted a lot of good info and Gauges
Old Jan 18, 2014 | 10:04 AM
  #32
Fal-308-Win
You do know your SG2 will read most engine codes? Do you have any??
Old Jan 18, 2014 | 10:08 AM
  #33
npccpartsman's Avatar
npccpartsman
Originally Posted by scrambler304
If I understand it right there is a coil on each side, 2 wires per coil, 4 wires bc of 2 coils in each. So I'm just checking the resistance of each coil?
Correct. Basically checking for a broken wire. You might also want to check each wire to ground for a short/chafe.
Old Jan 18, 2014 | 10:57 AM
  #34
scrambler304's Avatar
scrambler304
P0262 Injector Circuit High - Cylinder 1
I read the sitction fix last night half asleep so I'll look over it again with it in front of me.
Old Jan 18, 2014 | 11:37 AM
  #35
scrambler304
Ok. Cylinder #1. The front two are showing 0.7 between them and neither are connected to ground. The back two are 1.6 and both are connected to ground.
Old Jan 18, 2014 | 12:32 PM
  #36
BLADE35's Avatar
BLADE35
. Removed the cap today and found a white cream cheese looking crap on the inside of the cap. Idk, but has the EGR bypass so not sure where I'm getting that from. The oil looks good.
Well this Isnt Good
That Means OIL in the Coolant
Iv always Found on my gassers Coolant seeps into the Oil and does that, But your sounds the othere Way around
Hows was OIL Leval Today??
You may need a OIL Cooler IDK
Can you post a Pic
Old Jan 18, 2014 | 12:56 PM
  #37
scrambler304
Oil level is good and oil looks good. No milky. I know I have a coolant leak somewhere bc it's low.
I have a pic but its not letting me paste it from my iPad.
Old Jan 18, 2014 | 12:58 PM
  #38
scrambler304
So if two of the pins going to the #1 injector are going to ground then that means the injector needs to be replaced or can the coils alone be replaced?
Old Jan 18, 2014 | 01:52 PM
  #39
scrambler304
Nope. That didn't post the pic
Old Jan 18, 2014 | 02:17 PM
  #40
CPB1's Avatar
CPB1
Not really sure if that's correct or not.
Can you get at #3 and compare?
Old Jan 18, 2014 | 02:19 PM
  #41
CPB1's Avatar
CPB1
Do you remember what kind of oil you put in it?
Old Jan 18, 2014 | 02:59 PM
  #42
npccpartsman
Are you checking the harness or the injector plug where it goes through the rocker box? There are one red and one blue wire that go to one coil and one black and one white wire that go to the other coil. None should be grounded.
Old Jan 18, 2014 | 03:25 PM
  #43
scrambler304
I'm checking the injector plug going into the top of the motor just inboard of the valve cover. I didn't note the wire colors. There are 4 pins sticking up when the harness connector was removed. My thoughts were the back two pins were one coil and the front two were another coil. I have no connection from a back pin to a front pin.
Old Jan 18, 2014 | 04:04 PM
  #44
scrambler304
Ok, just check the connector for #5 (#3 was under a bunch of stuff). No pins were connected to ground. The back pins read 0.7 ohm and the front pins 0.7 ohm. So if that is a believed to be good injector and coils, then I'm thinking #1 coil and/or injector is bad, grounded on the rear pins?
Agree/disagree??
Also, the last oil was 15/40. Doesn't show the brand. I just know it wasn't rotella.
Old Jan 18, 2014 | 04:36 PM
  #45
CPB1's Avatar
CPB1
The oil:
As long as it was CJ4 rated then it's ok. Most 15-w40 oils are diesel rated oils.
The Injector:
At this point I would pull the valve cover. I would be double checking that injector (ohm reading) every step of the way to see at what point it is not grounded.
The HPO rail can be tricky to remove on that side if you get that far. There are 2 bolts that are difficult to access due to the heater/AC box.
