So I changed my lock cylinders today and took the door panel off and found some wires disconnected. Anyone know where they hook up to? Didn't see any connector it can go to. It's the black and white connector
Ok. Hoping it was the window plug or something. On the pas side control it doesn't roll up or down but from the driver side control I can roll it up and down
Done alot of audio work, thats what the guys say, speaker. as for that window issue, what side is this picture on? pass. or driver? maybe check the connection on your passenger side controls. maybe even go to a junkyard and pull off a window control and see if maybe its just a bad controller.
The pic is on the pass side. It's weird cuz the door lock will lock for pass side but won't unlock and the window won't roll up or down from pass side.
sounds like the controller, not sure on how to test them other than grabbing one from a junk yard (whole thing, splice your wires into the new controller) and see if it works. thatd be my 2 cents, controller and buttons and see what she does.
No controller/GEM on these trucks, everything is wired direct. Nice and simple.
