Alternator? 06 expedition
i had the blower fan on high, and the rear fan on medium, the headlights, foglights, flashers, and rear defrost on - just about the max load you can put on the vehicle.
everything was fine until i had to slow way down and the engine dropped down below 1000 rpm. if the engine dropped below that point, you could hear the blower fan slow down, and shortly thereafter the voltage gauge on the dash would start to drop as well.
that part isn't much out of the ordinary, but normally, the electrical would recover as the rpms increase just a bit. however, the voltage would not recover immediately as the rpms climbed.
at one point, the voltage had dropped after stopping to make a turn, and did not recover for a couple of minutes, and in that time the voltage gage was fluctuating on the low side of normal. then after a couple of minutes, the belt squealed, and the alternator came onboard, and the electrical recovered completely.
at the next turn, it would do the same thing. sometimes taking more than a minute for alternator to come back on board as the engine operated about 1500 rpm.
so i checked it out when i got home, and the alternator was covered in ice, and the entire engine compartment is covered in snow.
so my question is ... is the alternator failing? or is it just a case the worst case scenario that caused the alternator to not work right and the belt to slip at the same time?
it has never acted up before, but i've only had it a month or so.
the only other time ive ever had anything like this happen was busting through a snow drift in my explorer. that time the alternator quit working for a few minutes and came back onboard several minutes later down the road. so i know snow can do funny things.
any thoughts?
forgot to state that the battery is brand new.
thinking more and more that it was just belt slip. a new belt is on my to do list, but was hoping to wait for warmer weather because it needs at least one new idler (can hear the bearings in the idler rattling).
i also noticed my hand was very black fom just touching the rib side of the belt.
our weather has just been crazy cold and snowy this year so i havent been able to work on it since i bought it.
do you think the ice in the outside of the alt. had anything to do with it? maybe drowning it out?
very possible. not sure why it would be fine until the RPMs dropped to idle, though. then recover with a squeal after a minute or so. very bizarre.
it was fine today on the way to work and home.
i got a new belt for it, figured with 106k on the clock, it is probably due regardless.
worst case scenario, i suppose, is a new alternator is in order.
I believe that's what happened to you, the belt got wet and icy and could not grip the alternator pulley.
