Alternator Woes
Old Apr 15, 2007 | 02:33 PM
aj197816134's Avatar
aj197816134
Alternator Woes
Dont Kill me! I have a 1995 E-350 5.8L with the E4OD. Back in November I replaced the alternator. THis morning I woke up, started truck and the amp lite was on. Voltage showed low, I revved the engine and it came back up. I was at a stop lite, took off, belt started squealing, and the alternator kicked up to the 18 mark on the gauge. It stayed there with assys on etc, it even climbed up. To get home, I disconnected the voltage regulator, and we were fine, would yousay bad alternator or what? PLease help.
Old Apr 15, 2007 | 03:28 PM
t4kne's Avatar
t4kne
First off, it sounds like the belt was slipping because it is loose or it could be there was somethign on the belt to make it slip (water, grease, oil?). The voltage reguator is seperate? The alternator produces the voltage and the requlator maintains it so it does not go too high. If it went too high, I'd be blaming the regulator.
Old Apr 15, 2007 | 10:33 PM
aj197816134
I am guessing the regultor also, nothing was on the belt, it was like something made the alternator work really hard all the sudden and then the voltage went through the roof
