injectors
Old Jan 16, 2014 | 07:59 AM
Jerry Chaney's Avatar
Jerry Chaney
injectors
do I need to get every drop of oil out of injector cup, before reinstalling injectors?
Old Jan 16, 2014 | 08:04 AM
JT250's Avatar
JT250
I have never been **** about it.
Old Jan 16, 2014 | 08:11 AM
Tugly's Avatar
Tugly
It's not the cup you worry about, there's a hole in the bottom of the cup to drain it just fine. The worry is where that hole leads to. When you pulled the injector, all the fuel and oil in the head went down that hole... and there was quite a bit. You need to drain the cylinder, or you will hydrolock when you put everything back together. I use a Mity Vac with a skinny tube to insert into the hole, then pull everything out that I can.
The next step is to install all the injectors (making sure all copper washers are in place, there's no cover on the tip (if new), and there is an abundance of oil coating the whole injector for a slippery insertion.
After the sticks are in, leave the glow plugs out (for now). I use a screwdriver to short the two big posts on the starter relay - located on the passenger fender. This will turn the engine and blow the last bit of oil/fuel out the glow plug hole.
Caveat: If more than a trace of fluid is in the cylinder, it's gunna come out fast - really fast. If you do this in the garage and there's a bunch of fluid in the cylinder, expect to grease the hood, the fender, the walls, the ceiling, yourself, and the family pet. You can lay the valve covers over the heads as a precaution.
Old Jan 16, 2014 | 11:15 AM
HKusp's Avatar
HKusp
Put the valve covers on and loosely place one bolt in. Then short the starter.
al0311
Jan 16, 2016 12:43 PM
kyle j
19
Nov 5, 2013 07:19 PM
F0rdF0rever
22
Sep 8, 2012 06:22 PM
MustangMatt96GT
34
Nov 14, 2009 10:43 PM
brushfit
Sep 13, 2007 08:08 AM
