E99-99.5 Unit bearing conversion
Old Jan 5, 2014 | 11:14 PM
AIbandit's Avatar
AIbandit
I asked about this before when I was doing my brakes. After buying fancy e99 rotors my DR side unit bearing went out. 2 questions 1. Can I convert one wheel at a time? shouldn't be a problem right? only a slight difference in the rotor. 2. It's only the unit bearing and rotor that has to be purchased?
Old Jan 5, 2014 | 11:19 PM
AIbandit's Avatar
AIbandit
Also was there any difference in 2003? my jeep runs a 03 PSD D60 and I want to keep them close in case I break.
Old Jan 5, 2014 | 11:44 PM
Firefighter 1406's Avatar
Firefighter 1406
Only I noticed was that I had to shim out my caliper bracket a washers worth or it would scrap on the rotor. Other then that you are good to go. Get the abs unit bearings,cheaper and then you have a way to grease them.
Old Jan 6, 2014 | 10:09 AM
sean23johnson's Avatar
sean23johnson
^ what he said. Ran my truck this way for a couple years
Old Jan 7, 2014 | 08:22 PM
AIbandit's Avatar
AIbandit
Ok thanks guys.
Old Jan 15, 2014 | 07:50 PM
AIbandit's Avatar
AIbandit
Is 18A1194A the right rotor? websites say it matches but uhhh......
Old Jan 15, 2014 | 11:55 PM
AIbandit's Avatar
AIbandit
It's not fitting*
Old Jan 16, 2014 | 11:45 AM
AIbandit's Avatar
AIbandit
I have a 3 wheeled truck in my driveway. =/
Diameter is 14.53"
cholber1
Nov 3, 2014 06:53 AM
artieb
Apr 8, 2014 12:05 PM
F SUPER DUTY
Mar 14, 2014 01:12 AM
pjnadon
Jun 28, 2010 08:51 PM
oldkountryboy
Dec 30, 2006 05:09 PM
