i ha e fuel
Old Jan 15, 2014 | 07:49 AM
mknapik's Avatar
mknapik
i ha e fuel
Everything is finally working up to par with new motor but it will not fire off . Purged fuel system rocked injectors new glow plugs new controller and I'm still stuck on no go ant suggestions . I saw the motor run before plulled all k did was clean it and change the pulley system
Old Jan 15, 2014 | 10:58 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Crack all your lines and crank, best advice i can offer. Wait till theres fuel at all 8 and lock em down.
Old Jan 15, 2014 | 11:25 AM
mknapik's Avatar
mknapik
Thanks I'll give it a whirl when o get home from work
Old Jan 15, 2014 | 09:51 PM
Macrobb's Avatar
Macrobb
When you crack the lines and crank, make sure you have the throttle all the way at max. This will pump as much fluid as possible through the system, making it easier.
I just take the accel cable off the pump where it attaches(it just pops on/off), and the spring which pulls the lever towards idle. I can then just push the throttle to 'max'(as far towards the rear of the engine as possible), and it will stay. Then, just use a screwdriver on the starter solenoid on the passenger side of the engine compartment(Note, pull the little boot off the single, small terminal in the middle, and short it to the terminal which has a bunch of wires attached to it to crank).
Also, after getting fuel to each injector, tighten down the lines and give it a small shot of ether(*). You'll have a /much/ easier time getting it to fire.
(*Note: Make sure you don't have hot glow plugs when using ether. If you turned the key off and then on recently, wait for ~20s after the last click for it to cool down. Then give it a little ether and crank)
Old Jan 15, 2014 | 09:54 PM
mknapik's Avatar
mknapik
Okay sounds good will give it a shot after I get a new starter . I think its on the way out from cranking to much
Old Jan 15, 2014 | 11:14 PM
Macrobb's Avatar
Macrobb
If it's shot anyway, you could always run the thing on 24V, by putting a second battery between the + terminal on the battery and the starter's + terminal.
So long as you make sure that it's /only/ the heavy + starter terminal which is getting the 24V, you shouldn't ruin anything more than it already is.
This is one of those old tricks we've done in the past with an old, failing starter with nothing to lose.
Alternately, just /run it/. Make sure you've got good connections to the starter, and just crank it over, 15 seconds at a time, until you get fuel or your starter finally dies completely.
Old Jan 16, 2014 | 12:11 AM
IDI guy's Avatar
IDI guy
Are you sure that you have 12v to the IP shut off switch? Just sayin'...
Old Jan 16, 2014 | 07:09 AM
mknapik's Avatar
mknapik
Yes I have power to shutoff .
Oldschoolfordlover86
Jun 6, 2014 06:48 PM
MyMoneyPit
13
Nov 19, 2009 01:12 PM
SoccerFetus8
Feb 22, 2007 11:46 AM
Olds_442
May 5, 2006 12:37 AM
seizure911
May 9, 2005 11:40 PM
