Offroad & 4x4
ttb pivot bracket questions
Old Jan 14, 2014 | 12:41 PM
c_silva88's Avatar
c_silva88
ok so i have a spare set of factory ttb brackets and id like to modify them for 3 inches of lift. so my question is how far should i move the mounting hole down from the factory location to achieve this. these will only be temporary till i get some money together for cut and turned beams.
Old Jan 14, 2014 | 01:18 PM
tjc transport's Avatar
tjc transport
i ain't rite
you will need to get the truck completely level, then put the springs in. once all back together measure how far down you will need to go to re level the axle.
Old Jan 18, 2014 | 03:02 PM
hav24wheel's Avatar
hav24wheel
If going with only 3 inches for now, might be able to get away without any drop pivot brackets. But you would want to drop the radius arm brackets some.
Old Jan 18, 2014 | 03:23 PM
tjc transport
i ain't rite
3 inches of spring lift without lowering the center pivot brackets will make you about 25 degrees off camber.
Old Jan 18, 2014 | 04:48 PM
Nothing Special's Avatar
Nothing Special
I'm just a simple caveman, but wouldn't you need to drop the pivot point by the same as the lift? If you want to keep your camber stock you need to leave the entire beam where it was as the rest of the truck goes up. Now given that 3" lift springs don't necessarily give 3" of lift I see the benefit in tjc's advice. But it sure seems to be that you need to drop the pivot point the same amount as the springs are longer (when loaded).
Old Jan 18, 2014 | 05:10 PM
hav24wheel's Avatar
hav24wheel
Ya theoretically speaking yes, in reality, I know you can do 2 inches without dropping any brackets.
Old Jan 22, 2014 | 09:26 PM
c_silva88's Avatar
c_silva88
this is what i was thinking. my plans are to mod them for 3 inches of lift and build a et of adjustable coil buckets so i can fine tune it (i have a set of brand new
6 inch super flex coils from a 79 f150 my friend was gonna use but went with coil overs)
xjpilot
16
Feb 7, 2021 04:33 PM
ravens fan
Jul 27, 2013 04:02 PM
frankensteined_67
Offroad & 4x4
Mar 13, 2009 11:37 AM
fordfinatic
Offroad & 4x4
Feb 28, 2009 06:48 PM
