Offroad & 4x4
lifting 92 f150
Old Feb 26, 2009 | 04:14 PM
fordfinatic's Avatar
fordfinatic
lifting 92 f150
im getting ready to lift my f150 and i bought this kit from my buddy and it is a 4 inch lift and it has everything in it except the for the radius arm drop brackets and axle brackets i heard these are brackets are interchangeable between 4in and 6in kits is this true because i found a bronco at the junkyard with a 6 in lift on it and i was wondering if i could use these brackets off that
THANKS
Old Feb 26, 2009 | 06:32 PM
351slug's Avatar
351slug
Yes I think you are right. The top holes are for 4 inch and the bottom holes are for 6 inch on the axle brackets. The radius brackets are the same i believe? Skyjacker has the beefiest brackets. Just FYI, this is not TTB country and 9 out of 10 will tell you to do a SAS. If I was 20 years younger and had a big garage, I would be 1 of the 9.
Old Feb 27, 2009 | 10:04 AM
waynaferd's Avatar
waynaferd
I gotta 4" Rough Country and the only difference between 4 and 6" are the coil springs.....so the radius arm drop brackets will work......
Old Feb 27, 2009 | 02:31 PM
fordfinatic
ok and what about the axle brackets are those interchangeable?
Old Feb 27, 2009 | 07:54 PM
waynaferd's Avatar
waynaferd
Yep......what 351slug said.....mine have two sets of holes.....upper for a 4" lift, and lower for a 6" lift.....
So if I want to go from my 4" lift I have now to a 6", all I need is the 2" longer coils and too drop the axle halves down into the bottom hole in the bracket.
if you look at the brackets in the bottom you can see the two holes.....the smaller bracket on the right is upside down, BTW...
Old Feb 28, 2009 | 06:48 PM
fordfinatic
o thanks for the pics
ecampbell124
Mar 6, 2016 10:04 PM
White76
Ford Truck Parts for Sale
Jan 19, 2015 09:25 PM
427mike
Dec 12, 2014 06:05 PM
ecampbell124
May 5, 2014 08:38 PM
doug79
Jul 7, 2013 04:46 PM
