Riffraff CCV Mod
Old Jan 10, 2014 | 04:38 PM
SARDiverDan's Avatar
SARDiverDan
Riffraff CCV Mod
Has anyone taken this mod and made a closed system out of it? I have one on the way and would like to make it a closed system but I would like to see pics of others that may have this system and created a closed system instead of having the open hose. I know "a California thing" but the smog police will only allow a closed system here. Thanks for your time...
Old Jan 10, 2014 | 05:55 PM
sudsmcduff's Avatar
sudsmcduff
do a search here, or you tube. lots of people have done it with differnt containers. i just run mine out the back. if the smog shop wants money, they will pass you.
Old Jan 10, 2014 | 06:04 PM
SARDiverDan
Figured I would just put on the mod in a few days when it arrives and have something setup by my next smog check. Just had it done last month so I am good for some time but I want to get this done sooner than later. I have seen systems that tie into exhaust but I will keep looking for RR mod kit photos that have done this.
Old Jan 10, 2014 | 07:05 PM
Ponyboychris's Avatar
Ponyboychris
I've made CCV traps for people in the past that routes back into the intake. All you need to do is leave route from the doghouse to the trap and loop it back.
Here's what the trap looks like. Normally the grey hose inlets are on opposite sides when the trap is set up to vent to atmosphere.
Old Jan 10, 2014 | 07:22 PM
SARDiverDan
Thanks for the info, I guess my biggest issue is finding a pic of how it's routed back in and where it's connected. I can make something if I can find a good clear pic of it. I can use the RR mod and then place a trap at the end of the hose like this, just not sure exactly where it ties back into
Old Jan 10, 2014 | 08:07 PM
jasonc76's Avatar
jasonc76
wouldn't it be easiest to tie back into the stock intake location? flip the doghouse around, route it to your trap, and then route it back to the intake tube.
Old Jan 11, 2014 | 08:50 AM
Ponyboychris
Exactly, install the trap down by the lower frame by the driver's door. Route the two hoses to and from the trap and zip-tie/clamp them to the frame at the same locations.
Old Jan 11, 2014 | 11:53 AM
SARDiverDan
This might be a dumb question but are you basically routing it back up and connecting to the original inlet that was used before turning the dog house around 180 degrees?
Old Jan 11, 2014 | 01:18 PM
Ponyboychris
Yup, you got it.
Old Jan 11, 2014 | 02:02 PM
BadDogKuzz's Avatar
BadDogKuzz
Here is the problem I see with RR ccv kit and you wanting it to be able to be smog test ready. RiffRaff kit comes with a tube that you replace the stock intake tube. Stock has a port so you can tie it back into the intake but RR doesn't. If you keep the stock tube and put a cap on it you could then always just tie it back in when you need to test.
I myself went with a home made catch can and have it plumbed like stock. I will say it helps but I still get alittle oil in IC pipes. Down the road I am going to build another catch can with a better design with should catch even more oil before going back into the intake. I used a clear hose so I can see how oily it gets and now after about 15k the clear tube has some oil in it. I catch about 4ozs per 5k miles.
Old Jan 11, 2014 | 02:57 PM
SARDiverDan
Thanks for the pic. I need to build a catch for it and also purchase an addition piece of tubing and I should be able to work this out. I figured I would flip the DH, run the pipe as directed to can then run the second line back up to where the original line entered the intake to tie the system together. Just need to decide on proper size of can and placement.
Old Jan 11, 2014 | 03:43 PM
BadDogKuzz's Avatar
BadDogKuzz
Dan I used the copper scrub pads also in mine. But the next one I make I am going to use SS scrub pads and add 1 or 2 baffle plates at the top to help deflect some of the oil from getting out of the catch can. Now adding the baffles is something I have seem in the store bought type of catch cans, some have holes drilled in them and others had slits in the baffles. Now I know alot of guys put the catch can under the truck but I put mine where I did so the oil would run back down hill into the catch can or doghouse. The next catch can will also have the lower fitting to the doghouse at the bottom of the catch can so that most oil will then just run back into the doghouse. That way I should retain less oil in the catch can. Just to give you a few more ideas to kick around.
350on44s
Dec 29, 2009 12:51 PM
bigdummyford
Aug 22, 2008 10:20 AM
powerstrokin007
20
Mar 29, 2007 03:38 PM
thinksnow
Feb 11, 2005 05:51 PM
stroken444
Sep 19, 2004 03:37 PM
