How to manually turn on dome light
Old Jan 9, 2014 | 05:45 PM
smoky_diesel's Avatar
smoky_diesel
Question How to manually turn on dome light
Can't figure out how to turn on dome light, so I broke down and did the un-thinkable, I read the manual.... I know, I'm embarrased to have to admit it.
from page 66
Press and hold the top of the control to the full on position to activate the dome on” feature. This will turn on the interior courtesy lights. The lights will remain on until the bottom of the control is pressed.
http://www.fordservicecontent.com/Fo...US_10_2013.pdf
And no luck. Can hold the button down for a long, long time. The dimmer function works OK so the buttons are working. I would like to be able to turn on the rear light so my kids can buckle themselves
Old Jan 9, 2014 | 07:03 PM
720Deere's Avatar
720Deere
Sorry, I can't help you with that one. You seem to be doing it right. If I hold the button in the up position for a few seconds it comes on and if I keep tapping the button up the lights come on. My problem has always been getting them to go off without it dimming the dash lights.
Old Jan 9, 2014 | 07:36 PM
Iowa Ford's Avatar
Iowa Ford
Same for me Matt, I know it's not the answer Op wants but I usually get in truck first and don't pull door all the way to solve this issue.
Old Jan 9, 2014 | 09:41 PM
F16Vip3r's Avatar
F16Vip3r
On a similar, yet different, issue (HIJACK!), is there any way to keep the truck bed light on? Or is it only activated with the courtesy lights? I can't find anything about it in the manual, but have had numerous occasions where I wish I could put it on (without having to open the doors).
Old Jan 9, 2014 | 10:26 PM
TRENT310's Avatar
TRENT310
Or it times out and shuts them all off on you, as is usually the case I find whenever I try to use any of the vehicle lights as work lights.
The wiring diagram shows that it is wired to the same circuit as the interior lights. You could change that simply by adding a wire to an upfitter, or by using a relay with both N/C and N/O contacts if you want to retain the automatic activation of the cargo light with the doors.
Old Jan 10, 2014 | 05:34 AM
Averill7's Avatar
Averill7
On my June 10 build date 11'...I hold the instrument dimming light in, to the second click feel, for about two seconds and all interior lights and the bed light remain on. You have to press the button past the first stop, til you feel a second click, then hold it. Works great to turn on interior lights and bed light.
Press the bottom of the button all the way in, two seconds, lights off.
Enjoy
Old Jan 10, 2014 | 12:58 PM
720Deere's Avatar
720Deere
The only way I can recommend is to use the key fob unlock command. That usually gives you like 30 seconds of cargo light as well as the running lights and interior lights. Definitely not a long term solution, but if you are looking for something without opening the doors, it should work for you.
I have Recon bed lights in my truck with a cover and I wired them to the taillights with a switch mounted in the bed for this very reason. If I approach the truck and need something out of the bed, I just hit the key fob and flip the toggle in the bed. If I need the lights to stay on for a longer period of time, I just turn on the parking lights. I had considered using an upfitter switch, but then the only way to use the lights would be with the key on. As it is, I can use the lights with the key or I can use them even if the keys are in the house. That wouldn't work as well on a truck that doesn't have keyless entry, but it works perfectly for me.
Old Jan 10, 2014 | 05:16 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
from page 66
I assume you are holding the dimmer switch in the "brighter" direction.
In my truck, it takes 2seconds of holding the button in that direction for it to turn the interior lights on, and tapping the dimmer in the "dimmer" direction, turns them off.
Old Jan 11, 2014 | 12:21 PM
SurryGent's Avatar
SurryGent
I have wondered for a year now how to get the interior lights to come on. Thanks for the info, it works. Hold the upper down and it comes on, hold the lower down and it dims off. Thanks again.
briangp
Dec 4, 2018 11:25 PM
LillJunior
2009 - 2014 F150
Feb 1, 2018 05:40 AM
Cwby
Jan 13, 2007 08:21 AM
ChevySniper
1997 - 2003 F150
Feb 18, 2004 08:55 PM
dono
1983 - 2012 Ranger & B-Series
Jul 18, 2001 03:10 PM
