Dome Light Possible Glitch
Old Dec 4, 2018 | 10:21 PM
briangp's Avatar
briangp
So I figured something out tonight..... And im pretty sure it's a glitch in the programming of our trucks....
I had the drivers map light on when I was sitting in my truck. I exited the vehicle, locked it.... Then soon realized I had left the map light on. Went back to truck, pushed map light button again (keep in mind all the lights turn on with the doors) then exited and locked it again. Guess what, map light was still on.
Went back to vehicle, open doors (all lights on again) and I hit the right of center all off button.... Obviously no reaction again because all lights were triggered by the doors. Closed and locked. Map light was Still on.
The only way I was able to make the map light go out was turning the key on, waiting for the lights to fade out, Then pushing the map light button, and it finally extinguished.
Now I know this is kinda a null point since battery protection will cut the light out, but it still shouldn't have to be this way. Pretty sure Ford might have messed up the logic circuit on this one.
Anyone else have the same issue? Also, keep in mind I am a keyed vehicle, not a push button start.
Old Dec 4, 2018 | 10:25 PM
kho6658's Avatar
kho6658
Yep same here. Someone else mentioned it and I tested it to see if mine did the same.
Old Dec 4, 2018 | 10:32 PM
Hemmi06's Avatar
Hemmi06
VERY ANNOYING... Mine does too!!
Old Dec 4, 2018 | 10:33 PM
briangp's Avatar
briangp
Okay, I apologize if it's been covered, search yielded alot of results unrelated to this issue. Very annoying though
Old Dec 4, 2018 | 11:25 PM
18CCLBKR's Avatar
18CCLBKR
Press the dome lights off button and the map light will stay on and then you can hit the map light button to extinguish. Took me a couple of different tries to figure out.
JRussell3176
2009 - 2014 F150
Mar 23, 2017 12:09 PM
84StraightSix
Aug 31, 2014 12:35 PM
TexasGuy001
Jun 12, 2012 01:01 PM
dae06
1983 - 2012 Ranger & B-Series
Apr 23, 2009 06:37 AM
dono
Jul 18, 2001 03:10 PM
