Trouble with lights
Old Jan 8, 2014 | 10:22 PM
maverickfe's Avatar
maverickfe
Trouble with lights
Hello I have a 1974 F-250 4x4.What I'm having trouble with is it starts and runs. But I have no heater wipers dash lights or radio. I checked fuses and there all ok. Has anyone had this trouble or something like it?
thanks
Old Jan 9, 2014 | 06:31 AM
fmc400's Avatar
fmc400
MSEE
How did you check the fuses? Did you actually remove them and perform a continuity check? Do you have power on BOTH sides of the fuse with it installed with the key in the appropriate position? If you don't own a multimeter, consider the fuses unchecked.
Old Jan 9, 2014 | 01:54 PM
iggybob44's Avatar
iggybob44
Those circuits should all be "ignition on" only correct, fmc? well, except for dash lights, those should be "constant hot", like the headlights since they are controlled by the light switch. Dash lights could simply all be burned out, and not related to the other issues, but a tester would confirm whether power is actually making it to those particular fuses......
Old Jan 9, 2014 | 03:07 PM
maverickfe's Avatar
maverickfe
thanks for all the help I will try when I get home
Old Jan 9, 2014 | 03:19 PM
fmc400's Avatar
fmc400
MSEE
That's correct. Wipers and radio are available during RUN or ACCY; heater should just be in RUN. Dash lights are controlled through the headlight switch, which has hot-at-all-times available.
Smithville Shredder
Aug 17, 2018 07:57 PM
e30rik
Dec 26, 2016 12:23 PM
rckrwlr
Dec 27, 2007 08:13 PM
96psdkris
Dec 14, 2006 12:14 AM
gyger1
Electrical Systems/Wiring
Jan 16, 2006 02:10 PM
