humming noise
Old Jan 8, 2014 | 09:59 AM
mediaman67's Avatar
mediaman67
humming noise
Hi All
1996 Exp 4.0L OHV
wife drove it the other day, said made loud humming noise, then engine stalled.
drove it this am, did it to me too while idling in D with foot on brake... humms for about 1 min, and then stalls the engine...
if I rev the engine, was still doing it... but came and went when I was driving then till I got her home...
I know there is a black plastic cap that makes a similar noise but not as loud, this seems like something else... and the fact it stalled the truck is bothersome... it started up then fine, but still.
The only thing that is the same as when wife had it, is that both of these days are like under 10 degrees outside...
so, me thinks MAP? or something else that doesn't like these REALLY cold temps? or??
Thanks All!
Old Jan 8, 2014 | 08:11 PM
Mikeman's Avatar
Mikeman
Just throwing out an idea. Sometimes a vacuum leak can be heard as a humming or whistling (often it's a higher pitch). Running lean when cold can lead to stalling.
Old Jan 8, 2014 | 09:34 PM
mediaman67's Avatar
mediaman67
This is more like a deep growl - almost like an old style vaccum cleaner...
many have suggested it's the IAC, but I want to be sure first, before replacing it. -
Old Jan 9, 2014 | 11:46 PM
Mikeman's Avatar
Mikeman
Can you put one of those mechanic's stethoscopes on the IAC and see if that's your source of the noise?
Also, have you checked to make sure that all of the connections on the intake tube/hose between the airbox and the intake manifold are tight? Air sneaking in downstream of the mass airflow sensor won't be measured and throw off the computer.
Old Jan 10, 2014 | 06:57 AM
shorod's Avatar
shorod
My initial thought was also IAC, especially since the weather is cold and you have stalling at idle. The IAC is a fairly common issue, and it's also not uncommon for them to make a humming or buzzing noise when failing or binding.
You could unplug the IAC and see if the noise goes away. You might want to have someone helping though to keep the engine running at idle speed once the IAC is unplugged. Otherwise, unplugging the IAC might cause the engine to stall, even if it is not functioning quite properly.
An even better test of the IAC would be to use a professional scan tool to command the IAC to run the engine at a specific speed, then see if the IAC can achieve the desired engine speed and if it buzzes in the process. You'd probably need to do this when the truck and engine are cold though, in similar conditions as to when you're able to hear the buzzing.
-Rod
mediaman67's Avatar
mediaman67
Thing is, it only does this when the air temp outside is like under 15 degrees, and now, it's been in the 20's+ (feels like a heat wave) - so, she is not doing this...
Someone mentioned running lean would cause it to stall like that... so maybe the IAC is just old enough to not work properly when the temps really fall...
Im just curious what causes the cap to vibrate? - me thinks it's a sort of air release valve there, and if it comes out too fast, or at the right speed, the cap starts to humm...?
for those of you that are musical - it's humming a "D" above middle C - I have perfect pitch (curse and a blessing I guess)
I bought a new IAC... I figured for $40, what the heck, but I will also be sure all connections are tight everywhere... I don't hear any vacuum leaks.
Old Jan 10, 2014 | 07:05 AM
mediaman67's Avatar
mediaman67
also, the new one has a lifetime warranty - since it's so easy to take off and on, I figured can't lose.
anyone know if this issue would throw a code? - the funny thing, is that I have a 420 come up all the time, cuz I think my CC is shot, but yesterday, the CE Light went out on it's own!! - maybe the air is so cold that the downstream sensor is registering a normal reading?
I found a $5 trick for that too... gonna try that when the weather is warm again, just to see if it works... I don't feel like buying a new CC if I don't have to, and being a 96, it doesn't have to pass emissions...
Old Jan 10, 2014 | 10:31 PM
shorod's Avatar
shorod
The cap is probably just vibrating from the IAC solenoid trying to move the pintle valve but struggling for whatever reason. The cap just happens to be the least rigid point in that area so it's where you can easily feel the vibrations.
-Rod
jocasio
Nov 2, 2012 03:05 PM
01' Super Crew
1997 - 2003 F150
Feb 20, 2006 11:33 PM
Tomcep
1997 - 2003 F150
Apr 4, 2005 06:35 PM
dstarrington
Apr 28, 2004 08:00 PM
dbythesea
Jan 21, 2004 09:48 AM
