Dizzy Caps
Old Jan 8, 2014 | 05:40 AM
GaryLP's Avatar
GaryLP
Dizzy Caps
I have a question. I was told that you can run a newer style 2- piece dist cap if you also use the new style rotor on my 69 F E 360 stock Ford distributor. It is supposed to give a better spark. I have put a petronic [ spelling] kit in it now. I have looked but can find no info any where.
Old Jan 8, 2014 | 09:16 AM
orich's Avatar
orich
Yeah the 76 Ford Dura spark dizzy cap & rotor with the tower and the spark plug wires set.
These caps are have a wider spread point for the contacts for a hotter ign. coil, so they won't get a cross over spark jump at higher rpm. Plus you get to use the whicker spark plug wires like 8mm and up.
The Standard caps can only handle 7mm wires...
orich
Old Jan 8, 2014 | 09:35 AM
JEFFFAFA's Avatar
JEFFFAFA
That is true. As long as you install both halves of the 1977 and newer cap and it's matching rotor it's a direct fit. Ford did not change the dizzy's housing. Go with 1977 to about 1982 for application to buy them. 1983 and newer got squirrelly with the rotors and caps.
Old Jan 8, 2014 | 10:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by orich
Yeah the 76 Ford Duraspark dizzy cap & rotor with the tower and the spark plug wires set.
The V8 dizzy cap with the male ends and its adapter were introduced in 1977, not 1976.
Note % in front of the basic part number refers to 1977 at the bottom of the pic.
Old Jan 8, 2014 | 10:52 AM
orich's Avatar
orich
Okay well, So, I blew that. I know close don't count here.
For some reason. I keep thinking1976 was the last fe's made.
As all my books and other info only list the last fe being in 1976.
Then 77's 302,351,400 ~~~So that's my story g
orich
Old Jan 8, 2014 | 11:59 AM
JEFFFAFA's Avatar
JEFFFAFA
orich
You are correct Orich as far as the FE's are concerned. 1976 was the last year. But the two piece cap was introduced in 1977. Back then all V8's in cars or pickups took the same cap because all their dizzys were the same diameter with the cap notch in the same spot. So say a 1978ish 460 two piece cap will fit on a 1976ish 390.
Old Jan 8, 2014 | 12:11 PM
orich's Avatar
orich
Okay Jeff, Geez, I was about to swear off my Oxy pain meds for a week well one day
Old Jan 8, 2014 | 12:21 PM
JEFFFAFA's Avatar
JEFFFAFA
BWA-HA-HA
Old Jan 8, 2014 | 06:01 PM
GaryLP's Avatar
GaryLP
Thanks everyone for their input. Now I need to figure out weither 8 M M wires from a 351M or from a 460 would work better on my 360 F E.... Thanks Again Gary LP
Old Jan 8, 2014 | 06:36 PM
JEFFFAFA's Avatar
JEFFFAFA
Me personally, I'd go with 460 for the wires.
STILL AVAILABLE FROM FORD:
E6TZ12106A...upper half of the cap. Standard grey with aluminum terminals.
F5ZZ12106AA...upper half of cap. Standard grey with brass terminals.
E6TZ12200C.....Rotor
E8PZ12259P.....Plug wires. Ford Motorcraft are Excellent wires for stockish applications.
NOT AVAILABLE FROM FORD but I can run a locate on them if you wish or PM me for prices:
F3TZ12106A....Upper cap half off early Lightnings. Black in color.
F3TZ12A217A...Lower cap half off early Lightning. Black in color.
E2ZZ12A217B....Lower cap half in standard grey.
Old Jan 8, 2014 | 08:09 PM
BobbyFord's Avatar
BobbyFord
I like to get a set that you can tailor yourself. They leave the spark plug boots and terminals off so that you can custom cut them yourself, depending on how you'd like to route the wires.
Old Jan 8, 2014 | 09:57 PM
orich's Avatar
orich
Or the MSD Cap & wires. Wire set for a 460..
0rich
This is an old picture tho, since then went to the HEI Dizzy
Old Jan 8, 2014 | 10:14 PM
NumberDummy
D5AZ-12106-A .. Blue Dizzy Cap, replaced B7AZ-12106-A .. Brown Dizzy Cap that was used on hipo's.
D5AZ: 1975/76 V8's and hipos.
Old Jan 16, 2014 | 02:01 AM
rockittsled's Avatar
rockittsled
saving for future use
24 Carat
Jan 28, 2016 11:57 PM
ScallyWaggler
May 16, 2015 02:17 AM
Fett
Jul 24, 2010 05:45 AM
efif150
Jul 16, 2005 11:27 PM
paulcw3
Oct 24, 2004 03:55 PM
