Help
Old Jul 13, 2005 | 01:13 PM
efif150's Avatar
efif150
Help
i just replaced the distributer cap and the plugs and wires. im pretty sure i have the wires in the right place but it wont start. the engine will turn over but it doesnt fire what should i do.
Old Jul 13, 2005 | 01:25 PM
RR4E's Avatar
RR4E
First off, did it start and run prior to this tune-up? Was there a particular reason for changing anything at all?
I'd be looking for spark at the coil first. Pull the center wire out of the cap, and with a well insulated glove and insulated pair of pliers, hold it just above a good ground under the hood while someone turns the engine over for you. Be careful not to touch any of the sheetmetal while doing this.(Gives you a good jolt)
You should see a nice white/orange spark jump from the wire to the ground.
If there's spark there, make sure all wires are firmly seated into the cap, and check for spark at the plug end of the wire.
If you've got spark at both ends, it could be a fuel related problem.
Old Jul 13, 2005 | 04:08 PM
3/4T man's Avatar
3/4T man
I have seen people put the spark plug wires on in the wrong direction on the cap in other words the oppisite direction of rotor rotation and that will cause a not start situation identical to yours so check to see if you may have done that. remember the ford distributor turns oppisite of "ahhum" chevys.
Old Jul 15, 2005 | 02:19 PM
spikedog's Avatar
spikedog
Did you replace the distributor cap AND rotor? Can't change one without the other, unless you are really going cheap (usually a matched set). I know it's a long shot, but you didn't mention changing the rotor.
Old Jul 15, 2005 | 07:06 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You can go as far as changing two rotors to one distributor cap, I don't like to do it though, but changing the cap without the rotor ....
Old Jul 16, 2005 | 11:27 PM
SmokyOlFord's Avatar
SmokyOlFord
Pretty easy to forget to replace the rotor, I've done that one. Also I pinched a point wire under the cap once.
-Ed
Rudiak
Mar 31, 2012 03:29 PM
frenchy107
Mar 12, 2011 03:06 PM
BOOTROS
Electrical Systems/Wiring
Jul 1, 2005 02:40 AM
z 97ford1
Nov 26, 2003 09:40 AM
