Sponsored by: Real Truck
changing fluids
Old Jan 2, 2014 | 07:27 PM
kc day's Avatar
kc day
changing fluids
Hello, I was wondering what everyone is using for their trans, diff, power steering and brake fluid? I have been reading a lot of posts about Mobil 1 ,Redline and Royal Purple being used in various combinations for the f250.
My truck is due for a change/flush very soon and I want to get the best that I can for my truck. Thanks to all
Old Jan 3, 2014 | 02:36 AM
Bently_Coop's Avatar
Bently_Coop
As long as it is within specs go with it. I used the Mobil 1 synthetic ATF for the transfercase and will be using Mobil1 gear oil for the axles later. Transmission on my truck is supposed to use Mercon V (4r100).
With out model, year, and setup it is hard to say what you should use.
Old Jan 3, 2014 | 08:14 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Mobil 1 Synthetic ATF is MERCON V.
Exactly. Without knowing what truck you have all I can do is to tell you to use the proper fluid. The wrong fluid will destroy your transmission.
Old Jan 3, 2014 | 09:22 AM
Bently_Coop
Thanks Mark. I did not know Mobil 1 is equivalent. I may be able to get it cheaper then motorcraft or other Mercon V's now.
Old Jan 3, 2014 | 01:30 PM
kc day's Avatar
kc day
It's a 2002 f250 sc v10. automatic. thanks
Old Jan 3, 2014 | 02:25 PM
Mark Kovalsky
Then you need MERCON V. Mobil 1 Synthetic ATF is my choice for MERCON V.
Old Jan 3, 2014 | 03:53 PM
kc day's Avatar
kc day
Thanks Mark, I was leaning towards Mobil 1 or Amsoil. Any thoughts on brake and power steering? Thanks
danlee
26
Mar 23, 2022 04:34 PM
omanalansan
Sep 26, 2011 05:40 AM
PW01
1983 - 2012 Ranger & B-Series
Jun 30, 2008 10:55 AM
mtietz
Mar 19, 2004 02:05 PM
Kevin1C
Jan 21, 2003 04:13 PM
