mobil 1 mercon v ???
Guys i'm about to go under and flush the ATF. Every where I read suggest to use Mobil 1 Mercon V. I can't seem to find Mobil 1 that is labeled "mercon v"
this is what i find in the stores
Buy Mobil1 Dexron/Mercon Automatic Transmission Fluid (1 qt.) 98HC69 at Advance Auto Parts_____
Many thanks!
Many thanks!
If you drop the pan you will only get 5-6 quarts.
Here is the complete tranny flush procedure by Mark
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
edit:The tranny holds 18 but get 20.
No. The converter holds about 8 quarts, and another 5 or so will be trapped in the trans. You'll get some of that trapped fluid when you remove the valve body. You won't get the fluid from the converter unless you flush it or remove the torque converter drain plug. If your truck is a 2001 or older it will have a drain plug.
mtietz
03-19-2004 02:05 PM
