ICP Volts vs PSI
Old Jan 1, 2014 | 11:52 PM
73fan's Avatar
73fan
ICP Volts vs PSI
I've been looking around for the correlation for volts versus PSI on ICP. Can't seem to find it. Can someone help me? Problem is, my Edge Evolution allows me to monitor ICPV, but that's it. Thanks in advance.
Old Jan 2, 2014 | 12:04 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
https://www.ford-trucks.com/forums/1...d-voltage.html
Josh
Old Jan 2, 2014 | 01:50 PM
73fan's Avatar
73fan
Thanks, bullit. My 2003 seems sluggish on the lower RPM range so I was getting real curious to what my HP oil pressure was doing...
Old Jan 2, 2014 | 02:13 PM
Bullitt390's Avatar
Bullitt390
Check FICM volts and verify VGT% and boost.
Josh
Old Jan 3, 2014 | 12:41 AM
73fan's Avatar
73fan
FICM volts runs 47.5-48.5 The VGT duty cycle appears to top out at 65-70% while driving. At idle it will occasionally sweep up to around 85%. As for boost... let me check that again. Where I really notice it is on any incline with speeds of about 80 km/HR. The torque converter is locked, and RPMs low. I'll have a look again see what things look like. I have noticed that while the engine is cooler, it appears to make more boost than once it's warm, while VGT % remains relatively the same. Perhaps that's normal.
Old Jan 3, 2014 | 08:38 PM
73fan's Avatar
73fan
So today it was far too icy to get any more live data info. But today also the truck appeared to be in a better mood than I have seen in a long time! ICP voltage easily approached 4 volts, which normally does not happen without some flying RPMs. And at the same time, the turbo screamed like it normally doesn't. Sounded good straight piped today!
Old Jan 6, 2014 | 10:54 AM
73fan's Avatar
73fan
So the opportunity presented itself to have a look at some values. At 80 km/HR, if I give push the pedal as far as I can without it unlocking torque converter, VGT duty cycle is around 63% and boost at 5 psi. ICP voltage, 2.1. Does that look right?
Old Jan 6, 2014 | 11:13 AM
Bullitt390's Avatar
Bullitt390
Only numbers worth comparing are KOEO, warm idle and warm 2500.
Josh
Old Jan 6, 2014 | 12:26 PM
73fan's Avatar
73fan
Ok, I'll check and get back to you.
Old Jan 6, 2014 | 08:19 PM
73fan's Avatar
73fan
Here's what I got for info. (ECT 85°C) Warm idle: ICP V 0.9 Boost 0 VGT 15.3-85.3%
2,500 RPM ICP 1.3-2.2 Boost 0 VGT 38%
KOEO: ICP V 0.2 Boost 0 VGT 0%
On a side note, 2,500 RPM it almost felt like it kind of missed a little. At idle it just purrs.
LSO1123
13
Dec 1, 2011 11:16 PM
SUPERDUTY OUTLAW
Nov 6, 2008 07:11 AM
smoky_diesel
37
Sep 27, 2008 11:24 PM
79_250RangerLariat
Mar 12, 2008 05:05 AM
triton185
Apr 16, 2007 01:48 PM
