Low boost??
Old Nov 3, 2008 | 09:53 PM
SUPERDUTY OUTLAW's Avatar
SUPERDUTY OUTLAW
Low boost??
Need some help figuring out what if anything is wrong with my truck. With my edge evo (I know i'm trying to get a dp) turned up to race i can only get 19 pounds of boost wot on a pretty good grade. I have never seen it above 19 pounds even on extreme. So do i have a boost leak possibly i checked all the intercooler boots both sides and they are tight just don't know where to look next.
Thanks guys
Deven
Old Nov 3, 2008 | 09:59 PM
mongo75's Avatar
mongo75
Isn't that about normal? I know when I have my truck on the DP stock setting, even with single shots, it will only push about 15 lbs. Was it ever higher before? On my 80e I can hit about 28lbs, and in 140, I can hit 30 psi.
Old Nov 3, 2008 | 10:23 PM
SUPERDUTY OUTLAW
I don't know if that is normal or not, but you are getting in the 20's and i can't get anywhere close to that.
Old Nov 3, 2008 | 10:38 PM
Pocket's Avatar
Pocket
Edge Evo should be able to break over 20 psi in the highest setting. What are your EGT's like at WOT in the highest setting?
Old Nov 3, 2008 | 10:46 PM
SUPERDUTY OUTLAW
My egt's will push 1200 pretty easy got to 1283 is the highest for just a second or 2 and then let off didn't want to melt anything down
Old Nov 4, 2008 | 12:00 PM
BENG0924's Avatar
BENG0924
I have Edge and I can build 25 lbs all day long. I think you must hace a leak. Also I never have hi EGT' s unless I am under load
Old Nov 5, 2008 | 07:12 PM
mongo75's Avatar
mongo75
You can run the EGT up to 1500 w/o much concern, BUT for only a short time. I used to let off at 1300 * but when I was live tuning with Jody he said it's ok to run that high as long as you don't hold it there long, as it for a few seconds or so. I on;y get that hot if I'm smokin' a riceburner.
Old Nov 5, 2008 | 07:29 PM
big poppa's Avatar
big poppa
Are you sure your boost line isn't crimped or bent anywhere. Maybe the fitting needs a look at to make sure its tightly sealed and seated. Just a thought.
Old Nov 6, 2008 | 01:09 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
First off the tempurature is dependent on whether you are pre or post turbo as far as how high is safe to go and second if you are not getting much boost check your up-pipes. A leak on the up-pipes will allow gases that would spin the turbo to escape preventing boost. Look for black soot around the up-pipe connections.
Good Luck
Dave
Old Nov 6, 2008 | 07:11 AM
03_PSD's Avatar
03_PSD
i'm betting a leak somewhere. double check all boot clamps and check your up pipes. my 0.02
