Relationship between ICP pressure and voltage
I was just playing around with the data on ICP pressure as it relates to the voltage readings and I put this together:
https://www.ford-trucks.com/forums/p...ctureid=113208
The chart and the equations are from the data below:
A first order equation is below:
https://www.ford-trucks.com/forums/p...ctureid=113207
It's showing the stock tune values. If your running a tuned truck, you will monitor just the ICPv and use the above chart to find your ICP psi.
Some custom tune writers fool the PCM by lowing the ICP psi reading in order to get more PW. The ICPv don't change, but the ICP psi shows lower reading to the PCM and OBDII port.
Here is what my SRL++ tune looks like." Gauge 1" is "ICP Calc" an is my true HPOP reading. "Gauge 2" is ICPv. And "Gauge 3" is "ICP psi" and is what the PCM and OBDII sees.
Can you Post these ICP Readings On a STOCK Tune????
Thanks
I am just curious
Josh
