Engine rebuild
Old Jan 1, 2014 | 07:37 PM
jetdoc's Avatar
jetdoc
Engine rebuild
400K is all she wrote. I used a little over a gallon of oil last tank of fuel. Blow by is excessive and I'm going to do a compression test on it when the weather gets better and I get some new glow plugs. I'm planning on rebuilding this myself but I'm looking for some real world cost fiqures from people that have done this. My injectors and turbo have less than 10k miles on them and I'm just looking for long block information like things that need to be checked and or replaced etc etc.
I'm not looking to build a 600 hp screaming machine, I got the Mustang for that, I just want reliability back...
Looks like the Buckzooka (tm) is heading east...
Old Jan 1, 2014 | 11:05 PM
HKusp's Avatar
HKusp
Dude, if I ever get mine figured out I will be more than happy to lend a hand. I am guessing you're all healed up?
Old Jan 2, 2014 | 06:37 AM
jetdoc's Avatar
jetdoc
Yes and no. Yes, from the surgery from last April. It took me 7 months to do a pull up though without pain. I got hit with a door at work and got a severe concussion, it has laid me up for a while now.
Old Jan 2, 2014 | 01:39 PM
Christof13T's Avatar
Christof13T
If the cylinders are ok, you might be able to get away with just a re-ring kit.
There are oversizing kits available on fleabay with pistons at reasonable prices.
Things to do while its all apart...
Hone the cylinders
Lap the valves to their ports.
Check valve spring tension.
Inspect and or weld up the piston oil jets.
Inspect cam lobes for any excessive wear.
Check crank journals for scoring, scratches, wear.. measure very carefully.
Measure push rods for overall length.
Deburr the block.
Polish intake and exhaust ports on the heads.
Take it all to bare metal... apply paint of some sort.
If it turns out to be just slight dusting... you might get away with rebuilding for around a grand.
Old Jan 2, 2014 | 03:56 PM
Pikachu's Avatar
Pikachu
I keep seeing people suggesting welding the piston cooling jets. Aren't they furnace brazed already, or is that only for certain production runs? Or are the furnace brazed jets the ones that are failing?
Old Jan 2, 2014 | 05:06 PM
Bonanza35's Avatar
Bonanza35
Hows your CCV? Its not blocked is it? Dose the lid blow off? I take it its just not running right at all.
Old Jan 2, 2014 | 09:49 PM
jetdoc's Avatar
jetdoc
Smoke on start and excessive oil consumption and steady stream of vapor on CCV tube.
I was looking at a 08 F350 but after reading on the forum here with all the problems and poor MPG I'll just sink another 5k into my old truck.
Old Jan 3, 2014 | 01:33 PM
jetdoc's Avatar
jetdoc
I found a engine that needs cups on craigslist for 800 bucks. It has 260K. Debating whether to buy that and rebuild or just do mine.
Second thought....What kind of hoist/ crane and engine stand do you guys recommend? One ton, two ton? I've yanked a lot of engines never one as heavy as this..
Old Jan 3, 2014 | 02:12 PM
joeyd61's Avatar
joeyd61
1 ton will work, 2 ton is better...master overhaul kit 1000.00 from Clay. depending on heads.. machine work from 1000---3500.. It ain't cheep
Old Jan 3, 2014 | 02:35 PM
jetdoc's Avatar
jetdoc
Ain't none of this cheap! But it beats a truck payment I guess. I'm going to start searching CL for a hoist and stand...
Old Jan 3, 2014 | 02:56 PM
Christof13T
Harbor freight.
With a coupon Dwayne sent me i picked up a 2ton crane for around 175$.
I would not attempt a lift of one of these blocks with a 1ton.
Old Jan 3, 2014 | 03:07 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
If someone is charging that much just for machine work they are hosing you
Old Jan 4, 2014 | 04:55 PM
jccapri's Avatar
jccapri
No that's not to bad
Strip down and vat 200.00 to 300.00
True bore 350.00 to 450.00
Line hone 175.00 to 275.00
Surface true deck 200.00 to 300.00
Cam bearings and plugs150.00
Now the heads
vat 50.00
Surface 150.00
Valve job (no parts) 175.00 to 350.00
Port and polish 350.00 to 750.00
Now the crank
polish only 100.00
If needs turned 200.00 to 300.00
This is a rough guess at prices some need more work some less.
It's not hard to make a hole bigger but to do it inline with the crank new ball game same on heads a bigger port does not mean more power just bigger hole only. Your talking 40 plus hours of work.
Old Jan 4, 2014 | 05:01 PM
jccapri's Avatar
jccapri
Add 100.00 to 150.00 for resizing the rods
Old Jan 4, 2014 | 05:34 PM
Riffraff Diesel
PREMIUM SPONSOR
Depends on where regionally you are I guess, because we usually pay between $800-$1200 and that includes balancing.
jdhart73
Jun 2, 2012 10:27 AM
Flyin5
49
Mar 28, 2010 10:49 AM
notyettoday
Sep 29, 2004 02:22 PM
herdfan75
Jan 13, 2003 09:29 AM
herdfan75
Jan 7, 2003 10:09 PM
