4wd Front End Question
Old Jan 1, 2014 | 02:54 PM
TKegs763's Avatar
TKegs763
Howdy y'all it's me again.. I am bored, so I decided to try and find out why my front end feels terrible, like a vibration or hopping feeling on throttle and popping on take off. I think part of it is old injectors, but I know SOMETHING is wrong up front!
I've done the usual, tires balanced, different wheels, new LF hub assembly. Well during icemageddon a few weeks back I was able to use 4wd. It was grinding and had a "gear skip" feel to it kinda like the axle was skipping on something and not engaging. All 4 wheels was working though.
Anyways I am trying to get the RF hub locker off and I can't get it to budge for the life of me! Also noticing the little axle is turning when I turn the rotor. Am I doing something wrong here? I thought the little snap ring held it in and it should slide right out?
Oh, and Happy New Year Brothers!!!
Old Jan 1, 2014 | 04:50 PM
crop harvester's Avatar
crop harvester
might try soaking in penetrating oil over night,& try working loose with a rubber hammer.sounds like from the noises you need to disassemble,do a search,find instructions for ball joint replacement,like guzzles write up,it will help you through the project,you will find most any info & links needed at the top at "first read " section.
Old Jan 1, 2014 | 05:36 PM
TKegs763's Avatar
TKegs763
Thanks CH! I got the locker out and it is shot I think. Sounds terrible when I turn it by hand. Also there is a ton of slop where the axle sticks through the hub. I thought the snap ring behind the locker held all of that snug? The drivers side locker had slop in it also. Is this normal?
Old Jan 1, 2014 | 06:04 PM
mueckster's Avatar
mueckster
Sounds like the hub assembly needs to come out to inspect the stub axle needle bearing and rear thrust washer.
Old Jan 1, 2014 | 06:27 PM
TKegs763's Avatar
TKegs763
Are the stub axle needle bearings in the back part of the hub assembly? What is the thrust washer? Thanks Mueckster!
Old Jan 1, 2014 | 07:34 PM
crop harvester
check out them nice write ups with pics,when you get time,would be very helpful for first time in there.
Old Jan 1, 2014 | 07:45 PM
mueckster's Avatar
mueckster
Yes.
There is a grooved plastic washer between the stub axle shoulder and back of hub.
Old Jan 1, 2014 | 10:34 PM
mueckster's Avatar
mueckster
I don't know if you still need this, but here is guzzle's write up for greasing the needle bearings and explains the thrust washer arrangement. Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Old Jan 1, 2014 | 10:35 PM
TKegs763's Avatar
TKegs763
Anything helps! I appreciate it!!
Old Jan 2, 2014 | 06:29 PM
AllaboutMPG's Avatar
AllaboutMPG
Here's a couple of write ups I use for reference when dealing with steering parts and issues
Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
https://www.ford-trucks.com/forums/9...placement.html
https://www.ford-trucks.com/forums/3...f-150-4x4.html
Kymber
Offroad & 4x4
Feb 25, 2009 11:35 AM
Vosko
Oct 14, 2006 11:05 PM
eveready77
Aug 4, 2005 11:30 PM
andym
1978 - 1996 Big Bronco
Sep 7, 2003 09:23 PM
