AC Compressor Pulley Removal
Old Dec 30, 2013 | 02:38 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Does anyone have a write-up on AC Compressor pulley removal. I saw the SpringerPop write-up on the A/C Compressor Clutch Air Gap Setting, http://springerpop.net/F350/air_gap.html, but it doesn't go into removing the snap ring and then the pulley. Will the pulley come off easy or do I need a 2 or 3 prong puller?
Thanks for any help!
Old Dec 30, 2013 | 03:32 PM
Whitey Ford
SOLVED..... It was the belt making the squeaking noise. I can't believe it! Well I got a new idler and tensioner chasing this down.
Special thanks to F350-6 (Chris) and SpringerPop. I saw a thread by Chris that lead me to try my old belt out. What a relief.
https://www.ford-trucks.com/forums/1...ey-squeak.html
Thanks!
Old Dec 30, 2013 | 06:35 PM
F350-6's Avatar
F350-6
Glad to have helped without actually putting forth any effort, but for the sake of others, you might as well link the thread in question in case this one comes up in a search later.
And for the record, the pulley isn't hard to remove, just be sure to remove the snap ring before you stick a puller on there.
Old Dec 30, 2013 | 07:05 PM
jr2000sd's Avatar
jr2000sd
I'm chasing down the same problem mine started squealing after it got really cold out here so I spray them down with silicone spray and it helps for a few miles now it's back again but I don't know which pulley it is maybe I'll buy a belt first and see how that goes
Old Dec 30, 2013 | 07:10 PM
Whitey Ford
Excellent idea. I edited in the address. Is the bolt for the tensioner, the main one in the middle, regular threaded? I put a breaker bar on it but I didn't want to force it until I was sure. I put new pulley's on the old tensioner until I figure it out.
Thank you!
Old Dec 30, 2013 | 07:12 PM
SpringerPop's Avatar
SpringerPop
One of these days I'm going to have to get around to adding to that web page about air gaps, even if it's just text.
As you found out, the snap ring comes off and then the pulley can come off with minimal "coaxing".
I would add to carefully clean any and all "gunk" from around the snap ring area to ensure the easiest R&R of the pulley on the compressor "snout".
Pop
Old Dec 30, 2013 | 07:13 PM
F350-6's Avatar
F350-6
Yes, the tensioner is held on by just one regular threaded bolt. Just break it loose like any other bolt.
Old Dec 30, 2013 | 07:16 PM
Whitey Ford
Pop
I edited in that address. Thank you very much!
Old Dec 30, 2013 | 07:20 PM
SpringerPop
Glad I was of some remote help, Mike.
Jus' payin' my dues............
Pop
Old Dec 30, 2013 | 07:47 PM
Whitey Ford
I would have never believed that the belt can make a sound just like a bearing in a pulley going bad. Glad I didn't put money on it.
Got a new Ford Motorcraft Belt in Georgia for $41. Check the chart for truck compatibility.
http://www.ebay.com/itm/MOTORCRAFT-JK8-1223-AA-V-Belt-Fan-Belt-Serpentine-Belt-/390412057082?pt=Motors_Car_Truck_Parts_Accessories&hash=item5ae65f39fa&vxp=mtr
Good Luck!
marcogyver
Sep 10, 2016 08:33 PM
dognip666
Jul 12, 2009 12:38 PM
dognip666
Jul 4, 2009 10:17 AM
willie4406
1983 - 2012 Ranger & B-Series
Jul 7, 2006 09:01 PM
tractoman
Jun 22, 2006 12:29 PM
