How do I remove A/C pulley?
Old Jun 30, 2009 | 03:17 PM
dognip666's Avatar
dognip666
So I've got a 95' F-150 w/ 300 engine - the A/C has been nice and cold right along. A few days ago the A/C pulley started chattering and you could smell it burning up so I shut it off and limped along with this worsening rattle. I bought a shorter belt to bypass the A/C but it's pulley protrudes into the path of the shorter belt just a bit - can I remove the pulley from the compressor or does the whole unit need to be removed? I took the clutch off but I can't see what else holds the pulley to compressor. I don't want to assume it's a press fit and start at it with a pry-bar unless I hear that this is a good idea. Any info is much appreciated.
Evan J. West
Old Jun 30, 2009 | 04:38 PM
subford's Avatar
subford
It is held on by a snap ring. Remove the snap ring and you should be able to work it off by hand.
Number 1 is the snap ring.
Old Jul 1, 2009 | 07:26 PM
Pompanosix's Avatar
Pompanosix
FYI: You probably already got it, but I believe the bypass belt should be 94.5in... that's if I remember correctly from when I did mine.
Old Jul 11, 2009 | 05:36 PM
mpmusicman2004's Avatar
mpmusicman2004
Where did you get this picture?
Old Jul 11, 2009 | 05:54 PM
quicklook2's Avatar
quicklook2
either ford cd or ford service manual.
Old Jul 11, 2009 | 06:48 PM
mpmusicman2004
Where can I get it? I was looking for an exploded view of the compressor itself.
Old Jul 12, 2009 | 12:38 PM
subford's Avatar
subford
Here is a photo if that helps.
