CDR & turbo
Old Dec 30, 2013 | 12:49 AM
Macrobb's Avatar
Macrobb
CDR & turbo
OK, guys, got a question here:
I've recently(as in, 6 months or so ago) added a Banks Turbo to my truck.
If any of you have seen the banks sidewinder kit for these engines, it has the CDR moved to the intake, just before the turbo... and /upside down/, with the input tube coming in from the top, and the vapors coming from a hose going around and down to the front of the engine.
Now, I'm not sure of a couple of things:
1. If I'm putting say... 5psi of boost into the engine, I'd have to be drawing a bit of vacuum. Wouldn't this vacuum be higher than what's seen without the turbo? (Simply thinking in terms of the amount of air which needs to be pulled through a given size pipe).
If it is more, wouldn't it be sucking vapors(possibly at a fairly high rate) through the CDR?
2. If the CDR is upside down, any oil droplets that get up to it will be trapped, and go into the intake(or stay in the can), instead of draining back out of the CDR. Right? Isn't this a bad thing?
(Last time I took it out, it had oil in the 'bottom' of it... but I doubt it's been working correctly either)
3, Does anyone have a good picture of our CDR's internals and exactly how it works? Seems like that would be useful.
Thanks.
Old Dec 30, 2013 | 10:12 AM
tjc transport's Avatar
tjc transport
i ain't rite
i have the banks kit on my truck for the past 25 years and 475,000 miles.
never had any real problems with the CDR mounting, i just changed it every 150,000 miles or so.
Old Dec 31, 2013 | 04:25 AM
Ford F834's Avatar
Ford F834
Thanks.
Read this thread. Page 3 has pictures of one opened up. Unless you are running a very small, dirty, restricted air filter there should be no excessive draw through the CDR on account of it being turbocharged.
https://www.ford-trucks.com/forums/1...-is-a-cdr.html
52M37
16
Nov 7, 2020 07:15 PM
Nero Morg
Mar 10, 2016 10:56 PM
91dirtydiesel
Ford Truck Parts for Sale
16
Jul 24, 2013 09:14 PM
IHIDI6.9
Mar 19, 2012 12:09 AM
75diesel
Oct 31, 2008 11:40 PM
