What is a CDR ?
Old Dec 23, 2011 | 08:28 PM
swimnshoot's Avatar
swimnshoot
What is a CDR ?
I'm burning oil like fuel now that I'm back on the road with the rebuilt tranny. She rides good, doesn't smoke too much, except after idling long periods then accelerating, hardly at all on startup. But, she's burning about a quart every 50 miles ? Just replaced the rear main seal and no real signs of leaking anywhere else.
Saw a member on oilburners post up that a new CDR fixed this on his '88. I'm not a member there and couldn't ask. Anyone here know what they are, where to get one, and how much $ ????
Thanks in advance and Merry Christmas !
Kirk
Old Dec 23, 2011 | 09:53 PM
farmert's Avatar
farmert
CDR= Crankcase decompression regulator It acts like a pcv valve on a gasser. It is located under the air cleaner on the rear of the motor on a non turbo, and on the drivers side valve cover on a factory turboed motor. It is about the size of a tuna can, held on the intake with 2 bolts. Go to Ford or International truck dealers for a replacement.
Old Dec 23, 2011 | 10:31 PM
johnboggs21's Avatar
johnboggs21
thought id toss up a pic of what your looking for too for good measure:
Old Dec 23, 2011 | 10:32 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Here you go!
Old Dec 24, 2011 | 01:01 AM
swooshcmk's Avatar
swooshcmk
It's possibly also located inside the radio if you have a CD playing head unit.
Old Dec 24, 2011 | 01:21 AM
LSO1123's Avatar
LSO1123
You can try taking the CDR off and cleaning it real good before you buy a new one. Soak it in gas to get all the oil out then let it dry completely before putting it back on. May just need a good cleaning.
Old Dec 24, 2011 | 11:38 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
lol! iv never made that connection before.i like it.
Old Dec 25, 2011 | 02:42 AM
FarmBoyFords's Avatar
FarmBoyFords
Mine is burning oil also... Can a dirty CDR cause this?
Old Dec 25, 2011 | 03:07 AM
Skip1970's Avatar
Skip1970
i love the access vans have!!!!
Old Dec 25, 2011 | 08:39 AM
kb1jid's Avatar
kb1jid
b-uno yes nice access on vans on the back side of engine but NOT so nice on the front side Merry Christmas Everybody
Old Dec 25, 2011 | 11:37 AM
swimnshoot's Avatar
swimnshoot
Thanks for the help guys ! I pulled the air cleaner and there it was, along with a pinched throttle cable and vacuum lines. I'll pull and soak it tomorrow. The whole family is loading up in this red beast to visit family. Merry Christmas !
Old Dec 25, 2011 | 01:28 PM
vfelix702's Avatar
vfelix702
How long do you let it soak in a can of gas before you let it air dry to put back on???? ... Can I run my idi for a day with out the cdr while its marinateing in the fuel?
Old Dec 25, 2011 | 01:32 PM
IDIDieselJohn
About an hour, and once in a while during that hour, take it out, shake it, soak it back in, take it out, shake, and let it soak again for a while before doing that again.
Then let it AIR DRY ONLY!
DO NOT blow air into it, you can blow out the diaphragm inside!
Old Dec 25, 2011 | 01:38 PM
1stgen3rdgendodge's Avatar
1stgen3rdgendodge
I don't see why you couldn't just delete the thing all together. I have looked on my 6.9 and the CDR is MIA on my truck. I'm assuming it has been deleted off at some point in time.
Old Dec 25, 2011 | 01:40 PM
IDIDieselJohn
The older Dodge Cummins trucks don't even have one, they have a road draft tube...
