NP435 2wd vs 4wd
Old Dec 29, 2013 | 01:33 AM
jgavac's Avatar
jgavac
NP435 2wd vs 4wd
I did a little research, but can't seem to find a straight answer anywhere
I've got 76 highboy. 205 divorced case. Blown NP435. I have a lead on a np435 out of a 2wd truck in good working order.
Will a 4wd tailshaft housing (with the tcase shifter attachment on it) and yolk swap directly over to a 2wd transmission? If so, and assuming spline counts are the same, can I just stick it in?
Thanks in advance
Jameson
Old Dec 29, 2013 | 04:39 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
"If" I remember correctly, the older 2wd tranny has a 28 spline output shaft. 4wd is 31 spline.
Old Dec 29, 2013 | 08:55 AM
Drac's Avatar
Drac
Save the old ones
I had a 76 250 hi boy divorced t-case with a C6 and the yoke was not a slip on yoke. It had a large nut inside the yoke. So I'm thinking your hi boy 435 does also. The 2wd 435 should have a slip on yoke. So you'll have to swap tail shafts.
I took a 435 for a 2wd (slip on yoke) and swapped the tail shaft and tail shaft housing to switch it over for a 4wd married t-case. The housing is obviously very simple to swap out, but the tail shaft has to go out through the front of the case. Yep gut it. Sounds like a pain in the ***, but it's really pretty easy. These NP435's can be rebuilt for like $150-$200 if the gears are good. If you can get the 2wd version cheap, buy the rebuild kit and put one together. I can't believe they get $750 for a rebuilt NP435.
Old Dec 29, 2013 | 10:30 AM
smokenchoken's Avatar
smokenchoken
are you sure you didnt just break off a shifter fork?
Old Dec 29, 2013 | 06:29 PM
jgavac's Avatar
jgavac
Do they use the same yolk as the 4wd transmission?
Shifter forks are all in good working order
Old Dec 29, 2013 | 06:33 PM
lance65's Avatar
lance65
I have seen many 2wd trans with the output shaft threaded. and wouldnt a 2wd longbed with a center support bearing have a bolt on yoke? My C6 2wd has a bolt on yoke. So I do believe that a 2wd trans will work for you. If you find one with a slip yoke, slide it off and see if the end is threaded.
Old Dec 29, 2013 | 06:37 PM
stromburg's Avatar
stromburg
Jameson, I will check the spline count on the 2wd trans
Are we talking spline count for the yolk? if we are, just use the 2wd yolk if the splines are different
Old Dec 29, 2013 | 07:50 PM
lance65's Avatar
lance65
If you have a 2wd trans with a bolt on yoke, use it....DONE. If they have different sized u-joints,get a conversion joint...then DONE!
Old Dec 29, 2013 | 08:01 PM
jgavac's Avatar
jgavac
Ah ha! That's what I needed to know
Thanks
Jameson
Old Dec 29, 2013 | 11:59 PM
privateer, eh's Avatar
privateer, eh
The np435 in 78 f350 1 ton duallies have the 31 spline yoke held on by what I think was a 1 15/16" nut. Sold one last year to a guy who needed the heavy duty piece for his 4x4. If it helps
goneinsixty
Mar 22, 2015 07:57 PM
kilich
Dec 23, 2011 10:14 AM
nitrousbaby!
May 27, 2009 02:25 AM
fishmanndotcom
1966 - 1977 Early Broncos
Sep 23, 2005 12:37 PM
cies_69truck
Nov 2, 2002 11:52 AM
