trouble w/7.3 psd.
Old Dec 28, 2013 | 10:19 PM
kevinfreekev's Avatar
kevinfreekev
trouble w/7.3 psd.
Hi, my names kevin, i've recently joined F.T.E. I have recently purchased a 95 F250 kingcab w/ the 7.3 ltr psd & automatic, it's a longbd also.w/250kmiles & 80kmiles on the tranny. This is my first Diesel. I've allways heard such good stuff bout this truck plus I'm a Ford guy so here goes,when i got the truck on my test drive it died a couple of times at low idle, it was a one owner/same family truck.got it from the Son.He said that it was probably running like that because it needed a new fuel filter& batteries..so got those.still stalls at low idle? Then the other day i went out to start it & it wouldn't start then i saw the grey smoke,maybe i just didn't let the plugs warm-up long enough before turning it over.i put it on trickle charge for awhile & put a new valve on the brake booster n tried it again & it started w/just alittle grey smoke,let idle for awhile then turned it off then staed it again,this time w/ no smoke n it seems to idle fine but still cuts out/missing?
Old Dec 29, 2013 | 05:46 AM
tjc transport's Avatar
tjc transport
i ain't rite
you will be best asking these engine questions down in the 94.5-97 powerstroke engine forum.
the guys there will help you get it running like new in no time.
Old Dec 29, 2013 | 08:38 AM
Diesel_Brad's Avatar
Diesel_Brad
Sounds like you have a glow plug problem.
What do you mean by low idle? How many RPM?
kawasakiklx1
Mar 13, 2018 08:54 AM
rowdyredneck
Apr 11, 2017 12:18 PM
rowdyredneck
Apr 9, 2017 07:42 PM
99 300k+ stroker
Apr 29, 2014 06:02 PM
brian s/c s/p
Apr 11, 2003 04:25 AM
