Clutch Pedal Sticks to Floor
Hello all. First post here, but not my first Ford.
Just recently I was given a `96 F-150 with the I6 and 5-speed manual transmission by my late grandfather. I drove it around for about a week with no issues at all (solid trucks!). I parked it for about a week and a half until I got time to get emmissions for the tag and all that. Upon parking it, the truck was perfectly fine; now I hop in and realize that the clutch instantly springs to the floor and stays there. I'm able to pull it back up with minimal effort, and it will stay up. Almost as if there's a fine line "breaking point" halfway through the pedal travel that decides if the pedal will stay on the floor or all the way up...no real in between. Regardless the pedal motion has no clutch resistance (feels like a "cammed" spring is all) and does not disengage the clutch.
Fluid level is fine so there are no leaks. And it's odd that everything worked fine when it was parked. I'm led to believe that the master and slave are fine since the fluid level has gone unchanged. Or at least that's what I hope with me not seeing an external slave. Is this something common? And simple I hope!
Thanks,
Tyler
Thanks,
Tyler
Does not have to leak fluid to fail. Just like your brake system, it has rubber cups inside the master and slave cylinders. If either cup failed, it will not function and not likely leak either(at least not at first). Keep pumping the pedal and it might start to show signs of leaking by the outer seal.
on
Sounds like the clutch push rod has failed. Its attached to the clutch pedal with a plastic bushing and goes through the fire wall above the gas pedal to the clutch MC. Mine broke and I was able to replace with it with a JY one. The rod is sold with the MC as an assembly.
Regards
rikard
Regards
rikard
Not sure if this same 4 fingered clip fits those later plastic pushrod M/C's
Regards
rikard
Regards
rikard
Heres a thread on the same thing, has a couple pics. It is up under the dash a ways but easy to find, just move the pedal a little while you're looking down there. Mine did it last year, I ended up just putting a cotter pin in the groove on the rod where it goes thru the hole.
https://www.ford-trucks.com/forums/s...136&styleid=19
The bushing/retainer we are talking about is where the piston rod meets the rusty arm in photos 2&3.
Pushrod should be almost tight against the arm.
Your picture makes it look ready to fall off.
If that connection is tight and without slop, then you are likely looking at a failed master just as freighttrain said.
The 'piston' is inside the master cylinder, on the engine side of the firewall...
Alec94F150XL
27
04-19-2018 05:56 AM
Amish Ford
07-13-2016 06:04 PM
texastiger07
02-20-2010 05:57 PM
tseekins
03-01-2009 05:52 PM
