stalling issues
Old Dec 28, 2013 | 10:10 AM
GreenDinosaur's Avatar
GreenDinosaur
Originally Posted by Rasputin53
Put the points back in and see if the issue goes away. Might be a thermal issue with the Pertronix.
Try this and see what happens.
Old Dec 28, 2013 | 10:19 AM
GreenDinosaur
Another thing to check is the voltage on the coil while the engine is running, not supposed to have 12 volts when running on a pertronix. when i rewired my truck i got rid of the resistor wire from the ignition switch and used regular wire with a 1 ohm ballast resistor. only other thing i can think to check is if your ignition switch may be going bad.
Old Dec 28, 2013 | 11:47 AM
tcmitchell11's Avatar
tcmitchell11
[QUOTE=GreenDinosaur;13888685]Another thing to check is the voltage on the coil while the engine is running, not supposed to have 12 volts when running on a pertronix. when i rewired my truck i got rid of the resistor wire from the ignition switch and used regular wire with a 1 ohm ballast resistor. only other thing i can think to check is if your ignition switch may be going bad.[/QUOT
I already did the did the same already. Im adding holley fuel regulater abd gauge today. I changed tge wires yet but they seems pretty new
Old Jan 1, 2014 | 07:35 AM
ford6867's Avatar
ford6867
Check fuel lines and see if it is to close to anything that might cause vapor lock. I have had that problem before, but only after engine warmed upped. Always that chance something foreign in carb floating around and prohibiting fuel flow on occasions. I have done this before....at night I have opened hood and found a wire arching from bad ground. I know it sounds cheesy, but worked. I grabbed wiring harness and pulled, result was loose nut on solenoid.
seawulff
32
Aug 24, 2012 06:46 PM
slickeast
Mar 20, 2011 08:08 PM
mac10guy
17
Jun 14, 2010 09:14 PM
bigdog50
Sep 3, 2006 09:11 PM
MineralStang
81
Jun 4, 2006 10:57 AM
