Ok my cruise light will activate but won't hold speed, it shuts off when I tap the brakes. I did the self test and it went through complete. All buttons worked. After the test it did not show any blinks which according to the chart shows speed control switch faulty, I replaced the switch and does the exact same thing. The recall was also done. I really don't want to give the dealer $ 110 to diagnose it.
Quick question to help start on my "no cruise" issue, are the overhead console display and the cruise on the same circuit? 2000 w/v10, Both of those don't work on mine but I don't see a fuse that leads me to believe it powers those things. Any help appreciated.
All fixed! Turns out it was the servo. Boy did I get lucky, after a call to the local Ford dealer for the part $530 I stopped at a junk yard and they just happen to have a flooded excursion sitting there. $25 later my cruise works.
