Dash light fix
Old Dec 25, 2013 | 04:35 AM
brake4beaver's Avatar
brake4beaver
Dash light fix
Here's an easy fix for weak dash lights. I used these LEDs (cluster uses 5 bulbs). 194 LED Bulb - 5 SMD LED Wide Angle Wedge Base | Miniature Wedge Base LEDs | LED Car Bulbs | Super Bright LEDs
Much brighter than incandescent bulbs, and the factory dimmer still works.
Old Dec 25, 2013 | 02:29 PM
F100Trucker's Avatar
F100Trucker
That's a great idea. Did you order green leds or cool white ones? I'll look into it, thanks!
Old Dec 25, 2013 | 02:31 PM
Diesel_Brad's Avatar
Diesel_Brad
MUCH better than stock. Did you use green or clear?
Old Dec 25, 2013 | 02:36 PM
Franklin2's Avatar
Franklin2
I bet he used green. That's the main problem with the stock lights, the green/blue lense clouds up when the plastic gets old and won't pass any light.
Old Dec 25, 2013 | 07:29 PM
blue84f250's Avatar
blue84f250
I like it alot. Im going to bookmark the website and this thread so I dont forget.
Old Dec 26, 2013 | 08:01 AM
Gary Lewis's Avatar
Gary Lewis
Subscribed as I would like to hear what color LED's he used. I think I'll try the blue ones that are said to give 7100K light. That's a cool white, and should approximate our trucks' original lighting.
Old Dec 26, 2013 | 12:37 PM
Eddiec1564's Avatar
Eddiec1564
As I am currently redoing my 84's wire harness and dash. I'm going to check this out for sure!
Every one of those lens covers rotted off and I do not like the "warm" white light effect in the cluster. That green look GOOD! Need to see some blue clusters next!
Old Dec 27, 2013 | 08:52 AM
fordboy300's Avatar
fordboy300
Subscribed I hope to see what color he used I'm tired of having to squint my eyes at night or even turn the dome light on to see how much gas I have left lol!
Old Dec 27, 2013 | 09:19 AM
reamer's Avatar
reamer
the link shows a green led option
Old Dec 28, 2013 | 07:05 PM
quakerj's Avatar
quakerj
I'm putting these on my wish list. I installed a set of green 194 bulbs in mine, and painted the back of the bezel white. After taking out the old lenses, it's noticeably brighter than stock, but half as bright as the LED's pictured. Thanks for the info.
Factory tach and no trip odo? Curious what you had to do to get a factory tach in these trucks-- I hardly see them!
Old Dec 28, 2013 | 09:12 PM
F100Trucker
I just ordered a handful of them in green. I'll post when I get them installed.
Old Dec 28, 2013 | 09:24 PM
rowdyredneck's Avatar
rowdyredneck
Wow! Those are definitely going on my wish list.
Old Dec 29, 2013 | 01:18 AM
brake4beaver
Yes I used green LEDs, with those blue halfway melted filters removed. Oh and if any of the bulbs don't work just turn them around in the plastic socket and they should light right up.
Old Dec 29, 2013 | 10:40 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Wow. I have a very nice cluster in my truck, and the factory lighting works as well as it did when new, but it ain't anywhere near as bright as that.
I put all new bulbs in, and cleaned the dust off the blue covers prior to installing the later model tach/trip cluster. I just thought it was well lit......
Might have to see about getting some of these LED bulbs for the next time I pull out the cluster, to modify it for the diesel swap.
Old Dec 29, 2013 | 11:18 AM
Gary Lewis's Avatar
Gary Lewis
Yup. I'm absolutely going that way, but either white or cool white. But, I will have to find similar bulbs for the aftermarket gauges. Hmmm, hadn't thought of that.
