Dash light fix
Old Dec 29, 2013 | 11:24 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Originally Posted by Gary Lewis
Yup. I'm absolutely going that way, but either white or cool white. But, I will have to find similar bulbs for the aftermarket gauges. Hmmm, hadn't thought of that.
Some newer after market gauges use the 194 bulbs. Who knows, you might get lucky and find some that do......
Old Dec 29, 2013 | 08:00 PM
Gary Lewis's Avatar
Gary Lewis
Yup. This gauge from
VDO VDO
uses 158's, which use the same physical bulb but have slightly less light output. So, it looks to me like that would work perfectly, with the only possible problem being that it would be too bright. So, I could have the same color of gauge - especially if I can match the red of the needles.
Old Dec 30, 2013 | 05:50 AM
Brad from Oz's Avatar
Brad from Oz
Yup. This gauge from VDO uses 158's, which use the same physical bulb but have slightly less light output. So, it looks to me like that would work perfectly, with the only possible problem being that it would be too bright. So, I could have the same color of gauge - especially if I can match the red of the needles.
I think the OP said the original dimmer still controls these LED bulbs, so they shouldn't be too bright.
BTW - great choice of guage there, VDO are one of the few makes that are actually accurate, Stack are another but they are about twice the price of VDO. You guys get a great price on those VDO gauges too, we pay over $50 for the same item not including freight. I'm hoping to replace my entire instrument panel with VDO gear.
Old Dec 30, 2013 | 06:44 AM
Gary Lewis's Avatar
Gary Lewis
Thanks. Yes, he did say the dimmer still worked, so when I add two more it'll work better.
Old Jan 19, 2014 | 09:41 PM
holliday0's Avatar
holliday0
Just wanted to say thanks - I ordered the green LEDs, removed the blue filters, and it looks perfect. I used the same company in the link (superbrightleds.com) and they are located nearby. Shipping was fast.
Old Jan 19, 2014 | 10:08 PM
quakerj's Avatar
quakerj
Welcome to FTE! That company is based in St. Louis, so I assume you're in Coffeen, IL? I've been to the winery there a handful of times. I lived in Vandalia for a few years, loved that area.
Old Jan 19, 2014 | 10:27 PM
Gary Lewis's Avatar
Gary Lewis
Yes, welcome to FTE. This is the place.
Old Jan 20, 2014 | 08:39 PM
holliday0's Avatar
holliday0
Hey, that's cool - that's my family's winery. Let me know if you're ever in the area again and we can talk shop. Have a good one guys and thanks.
Old May 13, 2014 | 01:10 PM
k-mann10's Avatar
k-mann10
Anyone know how many bulbs are needed for the cluster? Though I would ask before taking the whole thing off
Old May 13, 2014 | 01:22 PM
ctubutis's Avatar
ctubutis
Something around a dozen (including the ones on the top edge - turn signals, BRAKE, etc.)
Old May 13, 2014 | 01:34 PM
Gary Lewis's Avatar
Gary Lewis
Look in your owner's manual. Mine says:
  • Instrument Panel Gauge Illumination: five 194's
  • Instrument Panel Courtesy: two 89's
  • Warning Lamps: seven 194's
Old May 14, 2014 | 03:31 PM
k-mann10's Avatar
k-mann10
Thanks. Yea 5 was number I needed for the gauge illumination. Going to be switching to some the led bulbs for better illumination and blue in color.
Old May 14, 2014 | 04:09 PM
  #28
F100Trucker's Avatar
F100Trucker
I did mine a couple of months ago and it turned out to look exactly like the dash pic in post #1. I also replaced my turn signal indicator bulbs (left and right). It also matched my new Kenwood DIN receiver in color. Really has a sharp look when driving at night.
Old May 15, 2014 | 09:27 AM
  #29
1986F150six's Avatar
1986F150six
I have a question for you intelligent people!
The original blue colored plastic filters do become opaque/cloudy with advanced age. In previous posts, some have mentioned removing the filters [some have crumbled away] and replacing with 194Blue and others have said 194Green. I would have thought blue would come closer to the original.
Which is right?
Old May 15, 2014 | 09:35 AM
  #30
ctubutis's Avatar
ctubutis
I chose blue because the mouse rubbers on the bulbs illuminating the headlights/wipers & ashtray bulbs are blue + there is blue tint in the HVAC panel.
IMO change all of it or none of it.
