Air Conditioning blows warm air when accelerating...???
Old Jun 25, 2003 | 12:56 PM
Ultrabusa's Avatar
Ultrabusa
Angry Air Conditioning blows warm air when accelerating...???
Help! My 1998 Ford Explorer is having an air conditioning problem. It hasn't totally stopped working, but is not working properly either. When we turn on 'max A/C' it initially works, although not at 100% cooling capacity; however, when engaged in drive and accelerating, it blows warm to hot air. With the temps now in the 90s it is unbearable and cannot be used. This is the opposite of any past experience like this. Usually, it works better while accelerating than sitting idle. I am assuming and hoping it is not that it needs a new compressor, since it works some of the time. Anyone else ever experience this? If so, what was the cause? Any suggestions or help would be greatly appreciated.
Old Jun 25, 2003 | 09:47 PM
speeder1's Avatar
speeder1
I can think of 2 things that might cause your problem, 1) your a/c might need to be recharged, being a 1998 model, if its never been recharged then that probably your problem, 2) if your accelerating hard or at wide open throttle the a/c compressor will shut off to take the extra load off the engine, thats all I can think of, I hope it helps.
Larry.
Old Jun 26, 2003 | 09:09 AM
Ultrabusa's Avatar
Ultrabusa
Thanks Larry!
It probably is the 1st thing you mention. The acceleration is normal, so I don't think your second idea is it. It stays warm the entire time it is in drive and the gas pedal is engaged....even at low speeds or constant speeds without hard acceleration. Thanks a lot for your help!
Old Jun 27, 2003 | 06:01 PM
rebocardo's Avatar
rebocardo
1998 Explorer has vacuum operated vents, does it not? I think your problem might be as simple as replacing the check valve inside the dash board.
Old Jun 30, 2003 | 12:05 PM
Ultrabusa's Avatar
Ultrabusa
Thanks for the tip. Would that problem (i.e the check valve in the dash) cause it to work some of the time (i.e at idle but not during acceleration)?
Old Jun 30, 2003 | 08:03 PM
LxMan1's Avatar
LxMan1
At higher rpm's, if it is low on freon, the pressure will drop low enough to kick out and cycle fast. This will keep it from cooling. I would check the charge on it and see if it is low.
Jimmy
redrangers
Escape & Escape Hybrid
Jul 22, 2015 07:48 AM
kdwyer
1983 - 2012 Ranger & B-Series
17
Jan 28, 2005 11:12 AM
diesel-lady
13
Sep 17, 2004 06:04 PM
f250mtnbikr
May 12, 2004 08:48 AM
kevinb68
Aerostar
Jul 6, 2003 12:11 AM
