Sponsored by: Real Truck
5R110 - is this normal?
Old Dec 21, 2013 | 04:32 PM
acf6's Avatar
acf6
I was driving with my windows rolled down today since its like 50* in december (wtf?) and noticed when i took off from a stop sign, my truck was squeaking/chirping/ticking. combination of that... If i just let off the brake and let my truck roll it squeaks a little, but as soon as i give it throttle it gets louder and faster. Stops instantly if i let off the pedal, and it either does it up to 10mph or i cant hear it over that. Didnt do it revving it up in park either
So i get home and jack up the front end, spin the tires, dont hear anything abnormal. Jack up the rear end, chock the front tires and put it in neutral and i went under and started spinning the driveshaft. Heard a ticking that got louder the closer i got to the trans, and the best i can determine is its coming from the rear of the trans. This is the best video i can get for now, and yes its supposed to be dark in the beginning. You can hear it clearly in the beginning
So am i screwed, is this normal, could it be something else..?
Old Dec 21, 2013 | 05:11 PM
Tom's Avatar
Tom
That's not good Miles.
NOT normal.
Old Dec 21, 2013 | 06:42 PM
02TB250's Avatar
02TB250
I'm with tom, that's not normal at all. I wouldn't drive it unless you have to until Mark chimes in. Hopefully it's something you can get away with some minor work and not a rebuild or replacement
Sent from my Galaxy using IB AutoGroup
Old Dec 21, 2013 | 09:48 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Bump for Mark
Sent from my Galaxy Tab 3
Old Dec 21, 2013 | 10:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I hear what sounds like someone walking.
Old Dec 21, 2013 | 10:32 PM
Bigpipes 35's Avatar
Bigpipes 35
Cracked flex plate perhaps
Old Dec 21, 2013 | 10:35 PM
Bigpipes 35
Scratch that because it does it without the engine running..
Old Dec 21, 2013 | 10:36 PM
Bigpipes 35
Sounds more like transfer case noise to me,
Old Dec 22, 2013 | 12:14 AM
twigsV10's Avatar
twigsV10
Can't tell much from the video, to much background noise. The most likely thing from what's described could just be a dry u-joint, Easy fix and with none greasable u-joints there going to go dry eventually.
Old Dec 22, 2013 | 04:35 AM
acf6's Avatar
acf6
In The beginning you can hear a ticking that gets faster the faster I spin the drive shaft. I'll try to take another video later today
Old Dec 22, 2013 | 06:37 AM
Mark Kovalsky
That describes a bad ujoint.
Old Dec 22, 2013 | 06:40 AM
acf6's Avatar
acf6
I sure hope so. Would a bad u joint squeak as well? If I'm in drive and just let the truck roll under its own power something lightly squeaks and then gets louder with speed not sure if I'm dealing with 2 problems here or what. When I was spinning the drive shaft the carrier bearing was making a squeaking rubber noise so maybe it's that
Old Dec 22, 2013 | 07:47 AM
acf6's Avatar
acf6
Just went out and spun it again, definitely dont think its a u joint. Still seems like its coming from rear of transmission/maybe transfer case. Trans fluid level is good and smells good (i changed it less than 5k ago), transfer case was also just changed under 5k ago with mobil 1 ATF. It also doesnt make the noise if i spin the driveshaft in reverse, and i didnt hear anything when i was driving in reverse yesterday either
You can hear it in this entire video, just need to turn your volume up. It seems to be loudest around :41 though
Im on the other side of the trans in this video, and it seems to be a little more noticeable.
Old Dec 22, 2013 | 09:39 AM
acf6's Avatar
acf6
so i have this now
along with these
not sure whats related, but i think the throttle position stuff is related to a problem ive been having with some surging switching from drive to reverse and such
Old Dec 22, 2013 | 10:38 AM
Tom's Avatar
Tom
Miles, would you like me to move this down to the 6.0L forum?
