rear axle lock ring
Old Dec 21, 2013 | 01:06 AM
ewoods8393's Avatar
ewoods8393
rear axle lock ring
Does anyone know what the part number is for the socket needed to remove the bearing lock ring out. I am trying to take the brake rotors off so I can replace them..
Old Dec 21, 2013 | 03:54 PM
88beast's Avatar
88beast
if you mean the one that holds the hub on its a 4x4 hub socket actually uh idr what for, but you can rent a whole set at any auto parts store. i just kept my rental
Old Dec 21, 2013 | 06:43 PM
1mouse3's Avatar
1mouse3
a screw driver an hammer also work, there not suppose to be tight. it is only suppose to be snug, on install turn till drum/rotor starts to becomes stiff to spin. if hard to spin, you got it to tight
Old Dec 21, 2013 | 08:58 PM
ewoods8393's Avatar
ewoods8393
The one was super tight. And it's a 6 pin lock ring
Old Dec 21, 2013 | 09:14 PM
1mouse3's Avatar
1mouse3
is this what your dealing with, if so it be tighter than i said. is it front or back your dealing with
http://www.justanswer.com/ford/1nu50...l-locking.html
Old Dec 22, 2013 | 01:26 AM
ewoods8393's Avatar
ewoods8393
Its the rear ones. I have mitchel on demand and it says to tighten them down and then back off of them and then final step is to torque them to 40 foot pounds. Finding the proper socket to remove them has proven to be a bit of a pain in the as*. I just wanted to do the brakes on this thing. When i put them back togather should they turn free or have a bit of drag? Following the inst from mitchell they have to be set to 40 ft pds and doing that puts a bit of preload on the bearing. The hub and rotor will spin but not very long where before I took them apart it would just spin free for a bit if that makes and sense.
Old Dec 22, 2013 | 02:53 AM
1mouse3's Avatar
1mouse3
that you should be able to get off with a punch, but here is a socket if you want one
http://www.napaonline.com/Catalog/Ca...180_0424508537
Old Dec 22, 2013 | 05:27 AM
tjc transport's Avatar
tjc transport
i ain't rite
are you talking about a F-superduty? because they are the only trucks that have rear rotors.
if so, you will need to purchase/rent a spindle nut socket for a Dana 80 axle.
Old Dec 22, 2013 | 11:54 PM
ewoods8393's Avatar
ewoods8393
That's what I have. It's not very common either. When I tell part places I have a f superduty they are like superduty 250, 350 or 450. I correct them over and over
Frank Murch
1978 - 1996 Big Bronco
Nov 10, 2014 08:42 PM
OLEVAFORD
Jan 27, 2013 02:02 PM
sgettin
Jan 1, 2010 11:37 PM
chief2007
Sep 22, 2007 02:15 PM
teederj2002
Jul 25, 2004 09:33 AM
