Broken antenna.
Old Dec 17, 2013 | 04:47 PM
dn29626's Avatar
dn29626
Broken antenna.
How do i remove the OEM antenna to install a replacement?
Old Dec 17, 2013 | 04:51 PM
F250_'s Avatar
F250_
The exterior mast screws off of a threaded post. [ Lefty loosey, rightie tightie.] The threaded post is attached to a flange which mounts onto the body panel with either 3 or 4 small screws, and the antenna cable plugs into the bottom of the flange and is routed through the firewall into the cab to plug into the rear of the stereo system.
Old Dec 17, 2013 | 04:54 PM
JOHN2001's Avatar
JOHN2001
I broke mine taking it apart so I went to a local junk yard and got the antenna and base off of a winstar.
Old Dec 17, 2013 | 10:40 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Im getting a new antenna off of one of our retiring ambulances.
Old Dec 18, 2013 | 05:09 AM
dn29626's Avatar
dn29626
Old Dec 18, 2013 | 10:13 AM
Supercab's Avatar
Supercab
Wink
Good Info!! Are the ones from the Windstar an exact match?
Old Dec 18, 2013 | 10:24 AM
JOHN2001's Avatar
JOHN2001
Yes. It was an exact match I'm about 99% sure it was a winstar... It's been a few years.
David it's an option for you now if you can find a van at a junk yard you can use the base and antenna off of it like I did. I did the same exact thing you did trying to get mine apart.
Pop the plastic piece up on both vehicles after you take the two screws out of the base. Carefully pull the base apart from the wire underneath it's just a slip on type deal if you drop the wire down in the fender it's a pita to get back up to where you need it. Everything just simply goes together. I didn't even bother disconnecting the antenna from the base in fear of the same thing happening.
Old Dec 19, 2013 | 04:41 AM
dn29626's Avatar
dn29626
Thanks guys.
vnleclaire
2015 - 2020 F150
Aug 7, 2018 01:31 PM
Jacob Bowman
Jun 4, 2018 09:32 AM
79 F-150 Stone
17
Mar 30, 2017 12:44 PM
beerguy5810
May 2, 2004 02:33 PM
LogicBig
Apr 12, 2004 02:42 PM
