Powersteering pump problem?
Old Dec 17, 2013 | 09:04 PM
coreyallan01's Avatar
coreyallan01
Originally Posted by 4CFarms
So if it has trouble turning then the gearbox should be replaced?
If you drop that draglink and you have issues turning I'd say the box is definitely suspect...
Old Dec 17, 2013 | 09:10 PM
4CFarms's Avatar
4CFarms
Ok so lastly, if I do replace the pump do u have any idea on the price or whether or not it is easy to do by myself or any tips so that it goes smoothly? Any tips are welcome
4CFarms's Avatar
4CFarms
So not the pump* the gear box***
Old Dec 17, 2013 | 09:14 PM
mjunk1's Avatar
mjunk1
I just did mine recently. It isn't a bad job at all. I recommend getting new lines, at least the high pressure. The pump is about $100 and iirc they are all made by Cardone so it really doesn't make much difference where you get it unless you are opting to get a new one from Ford. There are just a few bolts holding it to the bracket and you need a special tool to remove the pulley (you can borrow it from most parts stores). I used the plumbers tape on the threads going into the steering box and I recommend you do as well - mine leaked at first and I had to put on more tape.
Old Dec 18, 2013 | 06:44 AM
4CFarms's Avatar
4CFarms
Do u know what the tool would look like or is called? And I'm not familiar with the gearbox at all and didn't even know it had lines into it. Can I get those high pressure lines at the basic auto parts store with the gearbox too?
Old Dec 18, 2013 | 12:05 PM
mjunk1's Avatar
mjunk1
The tool is a pulley tool set. They will know what you need at the store and most of them let you borrow it. It simply clamps on the pulley and let's you get the old one off and press the new one on without damaging the pump. The lines should be accessible. You will need to see if your pump has 2 return lines or 1 if you buy the one with the bottle attached, or you can swap you bottle over to the new pump. Basic hand tools are all that is necessary except for the pulley tool. Line wrenches make it s little easier. I would spray the line fittings with some PB Blaster now if you can so it has a chance to work in there.
Old Dec 18, 2013 | 12:21 PM
4CFarms's Avatar
4CFarms
Thanks a bunch and I appreciate it. I will let you know tomorow how it goes and if it was the problem indeed!
boyer61
Sep 26, 2009 08:14 AM
FESTER1st
May 20, 2008 01:43 PM
joshsmith7
Jun 9, 2007 02:54 PM
getnbz
Oct 22, 2005 01:31 AM
ADSf100
1978 - 1996 Big Bronco
May 13, 2005 09:46 AM
