Sponsored by: Real Truck
power steering pump
Old Oct 21, 2005 | 03:12 PM
getnbz's Avatar
getnbz
power steering pump
i just noticed my power steering pump howling when you turn the wheel so i checked fluid added a little. i know the big tires doesnt help it but is something i should worry about!
Old Oct 21, 2005 | 04:08 PM
FortyFords's Avatar
FortyFords
Chk your ball joints,How many miles on your truck?
Some guys put Mobil syn in it?
Rich
Old Oct 21, 2005 | 04:10 PM
getnbz's Avatar
getnbz
i know its the pump not ball joint theyre new
Old Oct 21, 2005 | 08:11 PM
91GT turbo's Avatar
91GT turbo
Use a turkey baster to remove the fluid in the reservoir. Top it off with some mobil 1 synthetic. Drive it for a few days and repeat to cycle as much of the old out as you can. Did it a few weeks ago myself and I've had no more whining.
Old Oct 22, 2005 | 01:18 AM
Cowboy Brett's Avatar
Cowboy Brett
Were all of the ball joints replaced?
You might consider making sure all those front-end components have been greased properly. It makes a huge difference, particularly when you live where things get rusty.
Old Oct 22, 2005 | 01:31 AM
Boba Fett's Avatar
Boba Fett
Ford pumps are famous for howling. My 87 Mustang did it all the time when turning at low speeds. It might mean that your pump is on the way out, but also check:
What vehicle was your pump from? Some Ford pumps use ATF not power steering fluid. Mustang pumps are like that. Make sure you have the correct fluid in the pump.
If you do not have a serpentine belt make sure the belt on the power steering pulley is tight enough. You may be hearing the belt slip when the pump is in use. Also check the belt's drive surface for shine. If it shines is shot and needs replace.
I hope this helps.
Blackwaterforge
Oct 25, 2012 07:25 AM
Loaf4000
Oct 2, 2012 11:58 AM
400 .040over
Nov 22, 2011 06:48 PM
cpettymore7777
Sep 24, 2010 12:47 AM
ford-harto3457
Sep 20, 2009 11:05 PM
