Power Steering pump...
Old Sep 25, 2009 | 10:46 PM
boyer61's Avatar
boyer61
Ok, well i got that firebird, and i believe the pump is shot. Heres whats going on, stitting still, its really hard to turn the wheel, but if i rev it to about 2k rpms, i can turn it but the whines really bad. driving normal, like going around a corner at 45, it works fine. Is it the pump? i know its not a ford, but if somethings worng im sure you guys will know. One guy at work thinks its the rack, i dont see how that could be it. Also, when i bought it, it didnt have much fluid in it. i;ve flushed it and refilled it with lucas powersteering fix and fluid, thanks guys
Old Sep 26, 2009 | 08:14 AM
ctubutis's Avatar
ctubutis
You might see if you can rent a hydraulic pressure-tester gauge, hook it up to the output of the
pump and then test its pressure & flow rate....
