Problems with Lokar throttle cable assembly?
Old Dec 16, 2013 | 02:26 PM
perks56's Avatar
perks56
I am using a Lokar throttle cable assembly on my Holley 4 barrel on the 5.0 L engine in my truck and I am having problems with the bracket mounted on the carb flexing so I am not getting full throttle.
Is anyone else experiencing this? I have checked the mounting of the bracket on the carb and the throttle cable down to the Lokar floor mount gas pedal and all is mounted right but I am getting way to much flex.
Appreciate any comments or ideas.
Kevin P
Old Dec 16, 2013 | 11:40 PM
DGMFORD's Avatar
DGMFORD
Do you have any pics? I'm using a different carb, but getting WOT. There should be adjustments at the cable.
Old Dec 16, 2013 | 11:52 PM
52 Merc's Avatar
52 Merc
Lokar stuff is usually good quality and definitely pretty, better than most. But, on occasions, they are prettier than functional. It may be a case of a bracket needing to be made from stouter materials. You may simply need to make your own replacement.
Old Dec 17, 2013 | 02:30 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
If it is flexing I bet you are at WOT prior to the pedal being on the floor. That extra strain will bend or brake the stoutest bracket. Adjust the cable so the pedal is on the floor at WOT and you will not bend anything.
Old Dec 17, 2013 | 08:11 AM
perks56's Avatar
perks56
Thank you for all the replies, thought I had checked everything with adjustments so far but will try again this weekend when i have help.
Hard to step on pedal and check cable travel and such from in the cab, besides this is my daily driver and I don't want to immobilize it at all until the weekend in case i have to run for any parts.
Kevin P
Bozworth
Sep 16, 2013 10:25 PM
teardropty
Sep 26, 2011 06:56 AM
oldiron
Jan 9, 2010 12:41 AM
hippyman01
Apr 3, 2006 09:42 PM
cudaz101
Jan 30, 2006 10:36 AM
