Powerstroke Fueling Problem
Old Dec 16, 2013 | 10:22 AM
ford_pickup's Avatar
ford_pickup
Hi all,
I just bought a 1995 Ford F-250 Powerstroke, and it is having a fueling problem where it will suck the filter bowl dry sometimes. If I switch tanks or fiddle with the selector switch the light will go off and it will drive fine for a while. Someone mentioned to me that there might be a problem with the screen/filter assy in the tank but does it make sense for both tanks to be having this problem? My thoughts were maybe the selector valve getting stuck in between modes or maybe some clogging going on in there. Any similar problems or known problems that would cause this
Thanks in advance
Old Dec 16, 2013 | 07:51 PM
Diesel_Brad's Avatar
Diesel_Brad
Subscribed. Interesting problem
Old Dec 16, 2013 | 08:50 PM
irhunter's Avatar
irhunter
Could you explain what this means: "it will suck the filter bowl dry sometimes."? I can't picture the "filter bowl."
How does the motor run when this happens?
Roy
Old Dec 17, 2013 | 07:15 AM
Krisverde's Avatar
Krisverde
I wonder if the lift pump is failing.
Old Dec 17, 2013 | 08:46 AM
ford_pickup
The fuel filter housing is dry when the problem occurs if I don't switch tanks it will sputter out and die, the first thing I thought of was the lift pump but the po changed (my guess to try to rectify this problem) and if it was the lift pump why would switching tanks smooth the problem out for a while
Old Dec 17, 2013 | 10:34 AM
Diesel_Brad
Roy
the power strokes how a Filter Housing that a cartridge filter sits in then a lid goes on. It is NOT like an IDI that has a screw on filter
Old Dec 17, 2013 | 11:20 AM
irhunter's Avatar
irhunter
Thanks. Now I recall. I have done some repair and maintenance on PSD, but it has been a while. They have electric lift pumps?
I expect the OP will be better off posting on the PSD part of the forum.
Roy
Old Dec 17, 2013 | 08:15 PM
Diesel_Brad
Roy
94-97 PSD have a cam driven lift pump. 99+ 7.3s have a electric pump
Old Dec 17, 2013 | 09:18 PM
irhunter's Avatar
irhunter
Thanks. How hard would it be to by-pass the fuel-selector valve and run off just one tank (since the OP feels the problem could be in the valve) as a test?
Roy
Old Dec 18, 2013 | 07:24 AM
ford_pickup
I can do that but would have to cut hoses and didn't really want to do that, think I might drop the front tank today and if that looks good the selector valve will be much easier to get to
Old Dec 18, 2013 | 08:50 AM
irhunter's Avatar
irhunter
I current guess: intermittent air leak in the valve. Hard to picture what that would look like, however.
Remove valve, plug outlet, pressurize valve, add 12v to switch from tank to tank, look for leaks??????
Roy
ford_pickup
Feb 7, 2014 01:50 PM
ford_pickup
Dec 17, 2013 12:09 PM
dyna
Dec 20, 2008 02:17 PM
wayneF250
Sep 20, 2007 03:47 PM
bob boyd
Sep 29, 1999 04:47 PM
