Powerstroke Fueling Problem
Old Dec 16, 2013 | 10:21 AM
ford_pickup's Avatar
ford_pickup
Hi all,
I just bought a 1995 Ford F-250 Powerstroke, and it is having a fueling problem where it will suck the filter bowl dry sometimes. If I switch tanks or fiddle with the selector switch the light will go off and it will drive fine for a while. Someone mentioned to me that there might be a problem with the screen/filter assy in the tank but does it make sense for both tanks to be having this problem? My thoughts were maybe the selector valve getting stuck in between modes or maybe some clogging going on in there. Any similar problems or known problems that would cause this
Thanks in advance
Old Feb 7, 2014 | 01:50 PM
LxMan1's Avatar
LxMan1
Not really up on the diesel but it sounds like maybe a low pressure pump (in the tanks) issue. Could be a bad pump relay or ground.
ford_pickup
Dec 18, 2013 08:50 AM
ford_pickup
Dec 17, 2013 12:09 PM
kingandrew21
Dec 8, 2009 05:01 PM
nickpierce
Mar 23, 2007 12:28 AM
JOHNNY254
Aug 12, 2006 05:39 PM
