351W Camshaft Selection
So far my parts list for upgrades is as follows.
1) Davis Unified Ignition Ford Duraspark Distributor. http://www.summitracing.com/parts/du...view/make/ford
2) ACCEL OE Replacement Ford Dura-Spark Racing Coil. http://www.summitracing.com/parts/ac...view/make/ford (Looked at the MSD Blaster II with the OEM horseshoe hook up but it like the other performance coils require the use of a resistor if being used with a stock DuraSpark II system. Whats the point in having the OEM hook up if you have to cut it to splice in a resistor.)
3) Holley 4160 replacement 4bbl carb 600 cfm. http://www.summitracing.com/parts/hly-0-80452/overview/
4) Edelbrock Performer RPM cylinder heads 60cc chamber. http://www.summitracing.com/parts/edl-60229/overview/ (I had the plain Performer picked out cause for some reason Edelbrocks website was showing identical flow rates for the Performer and the Performer RPM head but now they are showing the performer RPM heads have better flow at .500 lift which is what the cams I am looking at is using.)
5) Edelbrock Performer RPM intake manifold. (It appears that between the Performer and the Performer RPM manifolds the carb mounting pad heigth is only 1/4" difference. Given the Performer is including the heigth of the 1" EGR spacer but I believe I can use the RPM intake with no problem as its only a 1/4" taller than the Performer with the EGR plate. I just dont know if it would clear my hood though with the stock aircleaner housing. I will have to do some measurements on car to verify this. If not then it looks like I am locked into the replacement performer manifold.)
6) Hooker Super Comp headers 1 5/8" primary tube and 3" collector. Planned on cutting the flange off and welding a ball flange collector on it from flowmaster. I also planned on modifying the headers by welding a bolt to cylinder #1 or # 1 and 2 to attack a fabricated heat shield for the hot air emission hook up on the oem aircleaner. I know this isnt needed but if I am going to do this, I have specifics of what I want to do and this is one of the things that will not change, if it has to then I will just go back OEM stock then cause this is a daily driver and I dont want to be cutting the car up making modifications just to get more power. I already have one streetrod and its a pain in the *** with diagonistics when theres a problem due to all the modifications. Plus it would also kill my goal of building the engine to appear factory stock to trick un suspecting people that dont know a thing about cars of the late 70`s.
As far as the looks goes, theres a few reasons why I am wanting to go back stock looking. One of the big reasons is this is a daily driver and I see no need in having show car features on the engine. One of the other reasons is that I can proceed to tell people I know that the car is stock. Such as Donny and the others that stop by at work that have hopped up show vehicles. They have beating cams in their engines but they dont make much over 300 hp. If I can get the car to look stock but put out more than they are then that would be great in my book. Yet another reason is the inspection station. The guy I used to work for I dont know if hes going to be **** about inspections or not. He didnt use to be but im hearing hes starting to be and if I can have it looking stock I can just convince him that it is stock and nothing is missing when in fact some stuff is.
The heat shield, they refer to it as an emission item but technically it doesnt do anything when it comes to emissions besides helping the engine to warm up faster if its cold outside. Personally I like to maintain this feature as it helps the engine warm up faster when its cold outside and while some say that its Texas it doesnt get that cold, I dont know how many days so far this year that ive had to deal with longer than usual warm ups. I hate to see how long it would take with out the setup pulling heated air around the exhaust into the carb. I mean I am willingly giving up the exhaust cross over through the heads and intake so I wont have the heat rising up to warm up the carb so I want to keep the heat shield feature.
As far as the headers goes, ford sold some vehicles from the factory with headers and I am confident I can pull off to majority of people that I personally know the lie that the car came with headers from the factory part of the sport package.
2) Ok, I can appreciate the advise to avoid spending money that isnt needed. But why would I be advised to get the RPM intake which builds power from 1500 to 6500 rpm when the engine wont turn much past 4,500 rpm and the plain intake which is cheaper last time I checked is designed for making power from idle to 5500 rpm? I dont want to argue I just want to know why would it be advised to go with a intake that will build power in rpm ranges that the engine will never see? I posted a question simmilar on Edelbrocks message board asking if there would be any negative effects to head flow running the Edelbrock RPM heads with a Edelbrock performer manifold. I wont be able to measure my hood clearance till tomorrow at the earliest. I dont mind using the RPM manifold and paying more for it, but I dont want to go with it if I the plain performer manifold would allow the heads to flow as advertised and build the same power up to 5,000 rpm. I am trying to figure out if its needed. I did all the comparing and the Performer RPM manifold is just 0.24" taller than the Performer with a 1" EGR spacer plate figured into the match. So I am wondering would a 1/4" taller manifold flow much more air than the 1/4" shorter. I would run a 1" carb spacer on the Performer if I went with that or just run it flat with the RPM without a spacer.
3) So spending a little more money and having a bolt in dist that was tuned to your engine specifications is not worth the money? I only ask because in the description it stated
Also I forgot to mention this, the inspection station I used to work at the guy who owns it which is the only inspector there. I dont know how to put it nicely, but he couldnt tell a thermostat from a radiator cap. He isnt too bright when it comes to cars and he works on them as well. Big reason why i went to work for him was to do the mechanical work and get paid for it. Long story short I ended up getting the shaft and moved on to a real repair shop. But I doubt inspections will be my problem for long, I have seriouslly been thinking about registering the car as an antique and get some plates with the 1978 sticker on it issued to it. I know that isnt supposed to fly but Ive seen to this date three people that had it done by stupid people at DPS allowing it.
~update~
Well apparently I as looking at the wrong heads when I said that the Performer and the Performer RPM heads had different flow rates. My orignal statement that they were identical flow rates was correct. I was looking at the flow rates on Edelbrocks website of # 60739 which is for the 1980`s and newer 351`s instead of the Performer # 60329 which is for the 351`s up to 1979. They have the same flow rate how ever which means reguardless of the head and intake combo they should still flow the same rate either with the RPM intake on the RPM head or just plain performer on the RPM head or vice versa. All I know is this starts to get to you when you have pages worth of notes going back and forth.
YEA, THAT WOULD BE MY SOLUTION, IF IT WERE MINE AND I WANTED TO KEEP THE STOCK AIRCLEANER, IT'S NOT GOING TO HURT ANYTHING BEING OPEN.
BUT SEE, YOU'RE ALSO CONTRADICTING YOURSELF HERE, YOU'RE GOING TO BUY HEADS THAT ALLOW THE ENGINE TO BREATHE IN THE UPPER RPM'S BUT GOING TO "PUT A CORK IN THEM" BY CHOOSING THE PERFORMER INTAKE ? AND ALS LIMITING THEIR USEFULLNESS BY CHOOSING A STOCK CAM ? WHAT'S UP WITH THAT ?
3) So spending a little more money and having a bolt in dist that was tuned to your engine specifications is not worth the money? I only ask because in the description it stated A LITTLE MORE MONEY ? $265 IS NOT A "LITTLE MORE MONEY IN MY BOOK, ESPECIALLY FOR A PART THAT'S NOT GOING TO YIELD $265 WORTH OF BENEFIT.
The whole point to this is to save me the headache and money in the long run. But at the same time there is also the very specifics that I am wanting to obtain out of the engine after the rebuild. If I was going to just simply get rid of say the oem steel valve covers, the oem air cleaner and go with "trick" parts on that then I might as well junk the oem air compressor the brackets and get a one belt system and go all the way to make it all look right. I am trying to do this for as little as possible but at the same time my ideal goals are 300 - 350 hp but ill settle for 250.
IF YOU WERE TRYING TO DO THIS FOR AS LITTLE MONEY AS POSSIBLE, YOU'RE SURELY GOING IN THE WRONG DIRECTION IN BUYING $1200 HEADS AND A $265 DISTRIBUTOR THAT AREN'T GOING TO GIVE YOU YOUR MONEY'S WORTH.
LET ME SEE...............2014 - 1978 = 36 YEARS OLD. LAST TIME I LOOKED ANYTHING 25 YRS OLD OR OLDER WAS AN ANTIQUE.
~update~
Bottom line here is you can achieve all your goals by acquiring a 95-97 roller 351 (I bought one last year at a local pick-a-part for $325 including the ZF-5speed bolted to it) and simply inspecting it, changing rings and bearings (if it even needs that, mine didn't) keeping the stock roller cam, removing the Thermactor bumps from the exhaust ports of the E7 heads (this takes all of a hour to do with a drill and a carbide porting bit, cleanup of the filings is easy on assembled heads, using a magnet a shop vac and a couple cans of carb cleaner) replacing the stamped 1.6 rockers with a set of Crane Energizer 1.7 full rollers, topping it with the RPM intake and that 600 Holley. You'll spend less than the cost of those Ed heads and have about the same power. You will though need that aftermarket distributor, unless you feel up to changing the cam gear on a stock Ford unit to a steel gear to match the roller cam.
1) No it wont hurt anything being open, but I dont want it open. I think it looks tacky and incomplete having nothing attached to that. You might be ok with having it left open and thats fine, but I am not ok with it and it surely doesnt hurt to fabricate up a small sheet metal shield to attach the flex pipe to. Would take all of five minutes to make one up and weld a bolt to the header pipe.
2) You will have to explain that to me on how the heads I picked are for upper RPM breathing. The smallest port volume for a 351W in aftermarket heads is 160 CC with 2.020" intake valve, so how is a 170 CC with 1.90" intake valve built for high rpm breathing? I fail to see this as 170 CC is about ideal for having high velocity at low rpm which will build low rpm torque. Now my only option would be to go smaller with a 160 CC aluminum head with 2.020" intake valve which I honestly think a 2" intake valve is overkill and is more for high rpm breathing than a 1.9" valve.
Also I fail to see how would the performer intake manifold put a cork in the heads? Even if I go with the plain Edelbrock Performer heads and use a Performer intake manifold the flow rates for the Performer heads are identical to the flow rates of the Performer RPM. So how is the performer intake manifold going to cork up the heads?
I also would like to know how would I be limiting these heads by using a stock oem replacement cam? The peak flow of these heads is 0.500" lift and the two cams I had picked out are just over 0.500" lift. So how am I going to kill the performance of these heads when the lift of the cam is at the upper end these heads are able to handle?
Also the big reason why I choosed a stock cam, is because this is an every day car. Why would I put a cam in it that pounds the ground and builds power up to 6,000 RPM when the car wont go past 4,500 rpm because of the 2.50:1 rear axle ratio? That is why I am questioning the advice you are offering because you are advising me to get parts that build high rpm power when the engine just wont turn those kind of rpm`s. honestly I think it would be a waste to have a high rise RPM intake that builds power 1200 to 6500 rpm compared to the performer intake that builds power idle to 5500 rpm when the engine wont ever see over 4500 rpm unless I deside to take the car up to 140 mph then I will start to pass 4500 rpm and then I would need upper rpm breathing.
3) Ok, its good to know that you dont think there will be a performance gain from having a custom tuned distributor for this engine. I will keep that advice in mind. I just would like more explination as to why a distributor that has been tuned for your engine and vehicle is not going to give you a performance upgrade. I would think a custom advance curve set to your engine and your vehicle would offer a bigger improvement to performance than a oem stock distributor.
4) Yes, the car is old enough to be registered as an Antique. But that doesnt change the fact that as I said that I cant legally use the YOM plates but I hope to get them issued. Reason for this is because after 1975 plates went to multi year and used plate stickers. The YOM law states that it has to be a single year only plate which these would not be. Ive seen three cars in recent time that had 1975 plates with the 78 plate sticker on it issued to the vehicle. I planned on going this route in the future.
5) Aquiring a late model roller 351W engine is easier said than done. Junkyards are round here typically dont keep parts once they hit a certain age. Some get rid of the parts after 5 years of not being current others wait till 10 years. Point is though why would I run out and buy a whole new engine for $1,200, and yes complete engines around here from the 90`s are no less than $1,000, when I have the engine and all I would have to do is go with better flowing heads.
As far as changing the distributor gear goes, thats not hard to do. I've done it quite a few times at work.
In the end the biggest thing that has me being reluctant to agree on much is because ive been questioned on everything. Ive been questioned on why I want the engine to appear stock, Ive been questioned on the intake choice I picked, Ive been questioned on the heads Ive picked, Ive been questioned on the distributor ive picked, etc, etc. Ive gotten nothing but questioned on my choices without being provided an explination as to why what I picked will not provide gains. The only thing I have gotten is advice that contradicts what I believe without any explination as to why it would be better to go with a manifold that builds power 1,200 to 6,500 rpm when the engine wont spin over 4,500 under normal street driving conditions. Its just like the heads, im being questioned on these being told these are high rpm power building heads but yet they are only 10cc bigger than the smallest heads offered aftermarket for the windsor small blocks. I think 170cc would be high rpm power for say a 289 and a 302 but for a 351 I honestly dont see how 170cc is too big nor how 1.90" intake valve is a high rpm power building size compared to the 2.02" valves.
If you are going to give me advice that goes against what I was planning atleast explain why and not just tell me it wont work right or its throwing money away and then say nothing else. It is frustrating as hell to have to go to these lengths to explain the reasoning for why I picked what I did only to get a simple response of its not going to work right. If its not explain why it wouldnt and what I should look at. If these heads are truely for high rpm flow and power building then what cc port volume should I look at then cause I can go no smaller than 160cc and then the valve size is 2.02" which is in my opinion a valve size for high rpm breathing compared to a 1.90" valve.
So all those Fords that had open ended snorkels are tacky ? That 50 cent hose Ford used to connect the snorkel to the exhaust manifold was tacky.
You don't understand where the bottleneck was on small block Ford heads (actually nearly all Ford pushrod heads were cursed this way) the bottleneck was the exhaust ports, not the intake sides. ANY aftermarket head will allow the engine to make power far beyond where your self imposed rpm limit is, this is why it's hard to understand why you'd spend $1200+ on a set of heads that are bigger than you'll ever use.
AAgain, you do not understand what makes power. Nor do you understand Edelbrocks marketing. The RPM heads are just a name to differentiate those heads from the Performer heads, they were never intended to be matched to the RPM intake (as a hard and fast rule) you are completely free to pick and choose parts combinations from what they offer. And you did not apparently comprehend what I said about using the RPM intake over the Performer. They're both the same on the bottomend, the difference is the RPM will allow the engine to make power above the point where the Performer quits. The fact that you say you'll never spin it above a certain point pointless, no matter what you say now, I can bet you WILL spin it above that point, it's human nature to use it (the added power) at some point (and more frequently than you might think)
Again, you're failing to understand engines and their components and the effect they have on how it performs. The camshaft is the brains of the engine, as a general rule, if you want to limit the power, then go smaller on the cam profile, if you want more power, increase the profile. But to a certain degree, you can have both by learning how cam profiles work, the wide LSA EFI style cams give you both power up top and excellant bottomend by closing the valve overlap (the time when the intake and exhaust valves are both open at the end of the exhuast stroke) there are those that say that limits breathing up top, but I have yet to see that to be true, it may do that on a race only engine that's built to maximize the total output to the nth degree, but squeezing ever ounce of power isn't necessary for a strewet motor such as yours.
The cam profile I recommended (the stock F4TE roller that comes in the roller 351W) is not a "ground pounder" cam. It's more of an "RV" style grind that's light years ahead of the cam that came with your 78 motor. The area "under the curve" (the time the valve is actually open enough to flow air) is vastly different between a roller cam and your smog era flat tappet grind, thus allowing the engine to make more power all across the rpm spectrum) And you're taking those rpm parameters that the advertising tells you too litterally, in actual operation, those parameters are rarely what actually happens.
What we're talking about here is "value for the dollar" spent. What I've been saying here is you're not going to see $265 worth of benefit from that distributor.You can tune your stock distributor to do what the $265 one will buy doing it yourself and spending $20 on a spring kit (if that much, I haven't priced an advance spring kit lately)
If you can't find a low buck roller 351, then you haven't tried hard enough. They ARE out there, you just have to look and be willing to pull it yourself.
If I can not get what I am seeking power wise out of the engine by going with the parts I want to then its not even worth my time and I will just put it back to stock specs then. I still have yet seen any explination as to why a high rise intake would perform better than the low rise performer intake manifold on this engine. I mean the car just physically wont see over 4,500 rpm for normal street driving. If I nail the throttle and hit passing gear the transmission shifts out of passing gear at 60 mph @ 4,500 rpm. In 3rd gear on the highway to run 75 MPH I am turning 2,400 rpm. So to see rpm over 4,500 RPM I would have to be going over 140 MPH. So this whole RPM limit I placed upon this engine is based off the physical limitations of the vehicle itself. With the gears and transmission the car has high RPM is just out of the question.
As far as to the edelbrock heads goes, Ive outweighed the benefits of going with the Edelbrock Performer or the Performer RPM heads vs modifying my old heads or tracking down some OEM heads that flow better and modifying them. In the end the edelbrock heads would provide me the most bang for my buck as well as giving me the added benefit of them being aluminum, and already able to run a roller valve train.
As far as the cams goes, Ive had numerous cams picked out but I crossed most of them off my list because I didnt think I would like the idle quality they would provide. Which is how I ended up with the two I found. One is a Crane Cam which is a stock street cam, the other is a comp cams one which is listed as being a oem replacement. They both are very close in specs but the other cams I found ranged from 110 to 114 LSA and I just doubt I would like those cams. I dont mind a exhaust note that has a slight lope to it, but I also dont want it to sound like its a hopped up engine either.
As far as the intake goes, I just dont think a high rise intake would benefit me considering the larger port volume of the high rise intake would cause the velocity to slow down at slower engine speeds which means they would start making power as the rpm figures stated of 1,200 to 6,500 RPM. Anything below 1,200 RPM and the velocity would be too slow for efficiency. Which I am sure it wouldnt matter in the sense that this engine spends most of its life between 1,250 and 1,500 rpm for normal city driving which is still with-in range of the highrise. But I just dont know if I want to go to all the trouble of making the highrise manifold work considering that it would require me either modify my hood or get rid of the OEM air cleaner to get it to clear it.
But I must ask though, if I go with these heads, 9.02:1 compression, the edelbrock performer intake (not the rpm) and one of the cams I picked out of my selection, would in your opinion it be possible to squeeze 400 ft lbs of trq and 300 - 350 hp out of the engine? If not what about 200 - 250 HP then? I am not building this engine to be like a racer or a pure acceleration vehicle, sure I might play around with it and do some mild street racing, but if I can put down a 0 to 60 mph in 6.42 seconds with just 145 HP engine I think I should be able to be competitive with a lot more modern cars with a 300 HP engine. The main goal though of this build is hopefully get a better power to weight ratio and have the engine struggle less to get the vehicle moving thus improving my fuel economy. If it helps below is a list of specs of all the cams I've looked at in order from what I most likely will go with to least likely.
1) 112* LSA, 107* Intake Centerline, 208*/216* @ 0.050", 0.530"/0.530" Lift
2) 114* LSA , 110* Intake Centerline, 210*/215* @ 0.050", 0.533"/0.533" Lift
3) 112* LSA, 108* Intake Centerline, 208*/216* @ 0.050", 0.533"/0.544" Lift
4) 110* LSA, 106* Intake Centerline, 212*/218* @ 0.050", 0.513"/0.513" Lift
5) 110* LSA, 106* Intake Centerline, 206*/206* @ 0.050", 0.533"/0.533" Lift
6) 110* LSA, 106* Intake Centerline, 206*/212* @ 0.050", 0.461"/0.474" Lift
7) 110* LSA, 106* Intake Centerline, 212*/218* @ 0.050", 0.513"/0.513" Lift
Out of these seven cams I found, I narrowed it down to number one or two. I like number three because of the extra lift to exhaust but I honestly dont think .011" more exhaust lift would make much of a difference, especially with exhaust valves that would be larger than the oem factory heads. Power wise out of number one, I am hearing that I should easily make 300 HP and 400 trq with that cam. That is about the highest I've gotten quoted out of the cams I listed above.
Now if number one is not the best choice, then what would you recomend out of the seven I listed. They are all hydraulic rollers, but they are not all made by the same people. What it all comes down to though is what will I have to go with to make everything work right with the performer intake. I know I could make the RPM work like ive done at work making parts work. But then it also comes to what ive read in my research on the matter, that is more volume the port has on heads the slower the velocity will be at slower speeds so less torque and maybe even sluggish performance. I would assume that the same would go with intake manifolds as well, so a larger intake while it would help with upper rpm breathing, I keep asking myself would the performer intake breath excellent up to say 5,000 or 5,500 rpm. They say that it`s operating range is idle to 5,500 rpm, if that is correct and they will work fine up till then, I believe that is what I would need to go with then. That would give me the low end power I want but also allow the engine to breathe at the upper rpm range that the car limits the engine to. I just dont want to end up with a high rise intake and making it work and changing a lot of stuff out and it makes a huge improvement on performance in the upper range of 5,000 rpm and higher. While that is great, I just dont think it would benefit me nor this car to make power at that high of a rpm range.
You're either not reading what's been posted here, or failing to comprehend it. I'm done. Go ahead and do what you want to do. It's going to be one huge *** disappointment.
