ignition switch
Old Dec 11, 2013 | 01:26 PM
abyars111's Avatar
abyars111
ignition switch
I have to replace my ignition switch. It doesn't make good contact in the start position. I've changed solenoid, cables , etc.
Are there any tricks? I guess I use a paperclip in the hole on the front to remove the cylinder? Do I turn the cylinder a certain direction to remove it and install it? How do you guys remove the large nut holding the switch in place, screwdriver? Is there a tool available for the nut?
Old Dec 11, 2013 | 01:55 PM
JEFFFAFA's Avatar
JEFFFAFA
Yep. Paper clip does it. Turn your key all the way to the left untill it stops. Push paper clip in the hole and push against a tiny button in there. While holding that button down turn key farther to the left. Remove cylinder and key. There was a tool to remove the bezel back in the day but I doubt you'll find one. I always have carefully used a small screwdriver.
Old Dec 11, 2013 | 02:14 PM
abyars111's Avatar
abyars111
Thanks for the help.
Old Dec 11, 2013 | 04:20 PM
yetiman38237's Avatar
yetiman38237
always wondered what that hole was for.....
Old Dec 12, 2013 | 09:35 AM
abyars111's Avatar
abyars111
The screw driver works well but can scratch if you have a stubborn bezel, ask me how I know. I found an ignition switch bezel tool if anyone wants one. Custom Machine Components also makes a tool for the headlight & wiper bezel.
Custom Machine Components Shopping Cart - Ford Truck+
Old Dec 12, 2013 | 12:57 PM
yetiman38237
Lol, I hate buying a tool I will only use once in a lifetime but then again I would hate a scratched dash as well....
66 twin i
Sep 16, 2009 10:20 AM
Ronnie Smith
Feb 19, 2009 08:20 PM
FdOverRebuiltDodge
Dec 23, 2008 07:37 PM
brider
Jul 10, 2005 08:04 AM
kwt
Feb 6, 2004 10:17 AM
