HELP - Ignition switch reinstall
Old Dec 22, 2008 | 06:44 PM
FdOverRebuiltDodge's Avatar
FdOverRebuiltDodge
help me put this POS ignition switch back in plz!!!
I used the paper clip to remove the cylinder .... now how to I get F-N thing back together..... ?????
thanks!!!!
Old Dec 22, 2008 | 08:33 PM
ol yeller's Avatar
ol yeller
I know you have to have the key in it. I broke mine getting it out.
Old Dec 22, 2008 | 08:46 PM
Bill W's Avatar
Bill W
I feel your Pain! took me a few days to get mine back in. Just keep trying, you'll get it.
Old Dec 22, 2008 | 09:16 PM
52 F3's Avatar
52 F3
You can see the pin that the paper clip pushes in in the lock cylinder. Line it up with the hole and push it in and turn to the left to put the cyl in the proper position. Then make sure the slot down in the switch is turned to the same angle as the tab on the end of the cyl (you can turn it with a screwdriver if necessary) then put the cyl in and turn it to the right one click.
Hope this helps. Easy to do. Hard to explain at the keyboard.
Old Dec 22, 2008 | 11:47 PM
daveengelson's Avatar
daveengelson
There is a slot inside the ign. switch and the lock has a corresponding pin that fit into said slot. The lock needs to be 'preloaded' by inserting the key and using the clip, urn the lock to the 'access' position, or all the way to the left, same position as when it was removed. Once the lock is inserted into the switch assembly and preloaded then turn the key to the 'on' position thus securing the lock into the switch assembly. If the lock is inserted incorrectly, that's to say, if you turn the key and the lock and switch rotate then remove and retry. Learned from experence, for the longest time I could remove the key with the truck running, took assembly apart and the light bulb came on when I figured it out. Hope it help, I read the instructions and does not make any sense to me. Again, think taking few minutes and look both components separately it may make more sense.
Old Dec 23, 2008 | 01:26 AM
FdOverRebuiltDodge
OK>... i got it back in..... i don't understand it but I got it..... I may have to do it again as I need to install or find a wire to run the ignition.... does anyone know what color the wire that runs the ignition is supposed to be....? thanx for all the fast responses!!!!!!!
Old Dec 23, 2008 | 03:28 AM
daveengelson
A belated welcome to the family of Ford Truck Enthusiast, welcome to FTE!! According to the wire diag. it's a 'yellow' wire. If intend working on the elect. circuits in the future suggest purchase the wiring diag. manual, I found it extremely helpful tracing any electrical gremlins that should develope. Majority of the Ford part suppliers carry them, or purchase from the supplier Jim Osborn Reproduction, posting a link to web site, manual cost $7 plus shipping.
Product List
Old Dec 23, 2008 | 03:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by FdOverRebuiltDodge
I need to install or find a wire to run the ignition, does anyone know what color the wire that runs the ignition is supposed to be?
Welcome to FTE
COLF12250A .. Ballast Resistor Wire-Ignition Coil (Motorcraft DY37)
61.50" long / Color coded pink / 1.30-1.40 ohms resistance / #20 gauge wire.
Fits: All 1960/72 cars & trucks.
Old Dec 23, 2008 | 03:52 PM
FdOverRebuiltDodge
Welcome to FTE
what happens if you just run a normal ballast resister?
Old Dec 23, 2008 | 07:37 PM
FdOverRebuiltDodge
update: I found the pink ballast wire..... i didn't check the resistance but It does have juice going through it so I think I am good..... thank a lot for the help
Galen Traphagan
Feb 10, 2015 06:38 PM
kalanborders
Jul 25, 2014 08:17 AM
tbugher62
Dec 15, 2013 06:29 PM
logcabinford
Apr 16, 2012 09:14 PM
ahurt1973
Oct 25, 2006 02:52 PM
